The Wasteland - ACT Style
krzysiu
Oh yeah :yes: modern Lego is so nice.
I bought a vintage lego train at trash n treasure, $60, expensive? when i got home i looked it up; $500 for a complete one, $3500 in the box. Its missing a couple of common bits which i have. :banana:
That Nissan motor.. i was thinking, its like two moto gp motors, roughly twice the capacity and nearly twice the output.
But it needs a turbo.... if its a high maintenance race engine, its no improvement ( apart from fuel efficiency), just a new size.
If its a reliable street car engine, then its a real winner, as long as its not incredibly expensive.
It would go great in a Lotus or similar..... no, two in a purpose built 600kg racecar! YEEEEAAAAH! :laugh:
Checked out the new IGA Drakeford the other day (because I don't already have about 6 supermarkets within 2 mins of my place lol) and was pretty impressed. It's bigger than I thought, and it's all so new and shiny :D
thanks Shell. Think I'll go there.
I normally do Woolies at Lanyon (easier than Hyperdome for parking close and don't have to put up with shopping mall crowds)
but I'd rather support the smaller traders
Supabarn near Red Rooter would be nice and close for you too, and an independent trader. I usually shop there - fruit and vegie section is awesome and it's a big shop but you can park at the door.
I like their rewards card too - I have received quite a few $20 vouchers and it's not like I even buy that much (not like shopping for a massive family!) :D
And just for you, there's a bourbon fridge :D
    • Its likely to be 70% road 30% track usage, track usage will increase if anything. Decided not to fit it as I cant be arsed changing the bushes on my LCAs again 🤣 I did get the below back from GKTech though so they should work together     The anti-squat kit and roll center adjusters work independently since they change the rear lower control arm's angle in different ways. The anti-squat kit adjusts the angle from front to back, which impacts anti-squat values. Roll center adjusters change the angle side to side, mainly to correct geometry on cars that are significantly lowered. They might affect each other a tiny bit, but overall, you can think of them as separate.
    • What are you doing with the car? street car or race car? People get hung up on the squat of the s/r chassis rears. There is positives to the squat if a car is setup and driven correctly for it (correct ride height, spring rate, alignment, damper valving). Generally just lengthen the rear traction arm by 5-10mm and that will help the squat and bump steer too. You are also correct with the roll centre too. This too also needs to be adjustable if you start messing with suspension geometry.   Having done quiet a bit of testing on race cars this year in regards to rear squat, I've seen some big positives from it in regards to drive off corners and traction.
    • I find I am using the MX5 for everything except long overnight cruises with Jackie, or, if picking up the kids to go somewhere, the SS has so much more room inside, and is much more comfortable if your going to be doing Hwy driving for 6-8 hours And the MX5 isn't bad in stop go traffic for a manual transmission car, whilst the clutch kit has been upgraded from stock, it is still light, and also not having a stupidly light flywheel in it helps as well, I've spent alot of time sitting on the M5, M4 and M7 stuck in traffic when plodding around the Greater Sydney Region in it Another benefit is MX5's are not really a car that gets stolen, you can pretty much park it anywhere, and it will still be there when you return
    • I can totally get why you like it for that sort of commute. I was thinking BoganDore because it's such a lazy drive, for things like stop start traffic.   I used to do over an hour in stop start shit from one side of Bris to the next, twice a day. My choice of car was larger displacement, with an auto. Basically for torque in low rpm/very low speed, and no clutch pedal. But loved a fun manual for the weekends, which the partner has (plus had the LandCruiser too for other fun drives). I now have an EV as a work car, and I tell ya what, ultimate daily driver, especially if youre out of energy, like I often am after work. I don't even need to touch the brake pedal   That said, I'm presently rebuilding the Liberty GTB to get it setup for weekend drives and track abuse! So small high revving turbo engine with 6 speed cog swapper!   But for your style of commute, I'd probably take the MX5 too!   For those choices, I'm ignoring fuel economy. Because I know how atrocious V8 daily life is for fuel from when I used to daily a manual SS, ha ha. Hence why I know I love the daily rumble of a V8
    • II know what u are saying after 9 years of hibernating my stock engined  110,00km gtt I got it registered 2 weeks ago. Took it for a drive a couple of days ago and some fresh bp fuel, I just couldn’t stop grinning and dreaming of when I will start my build thread. its just such a primal man feeling many forget to enjoy I wish u so much enjoyment with your little racer mate
