Yeah my one there. Yeah I still play a fair bit of iracing and race a Monday league on lfs. Too much fun haha
Heard about GT Academy? Should enter.
http://www.skylinesaustralia.com/forums/topic/439832-gt6-gt-academy-gamers-to-racers/
Edited by RosieR34
I'd like to, but my gear won't work on PlayStation, and I think I'm too used to it now to play with a controller .. Good excuse to upgrade to a new wheel though haha
Haha if you got the skills then why not. In the US it's 45 out of 400,000. AU might be like 45 out of 10,000 LOLOL. All you need to do is post a good time online then you move to the next round - if you're skilled enough with a controller then why not :P
That's a good point.. I shall look into this more haha
So decided to bake a cake with mum. I kinda got carried away with my design. The idea is nice but I can tell this GTR cake is going to look terribad! Haha! I'll post the end pics if it looks anything like a GTR :P
Edited by RosieR34
Cake is not the correct mixture for what I want to do. From what I've been reading / seeing, "Cereal Treats"; those rice bubble things will do the trick. It molds perfectly and I should be able to create a GTR. It may not taste the greatest but maybe some cakes around it :D
Someones been reading my private book of ideas and inventions. :ph34r:
Bastards!
Actually its a logical step that im sure thousands of people have thought about putting together.
Still.... its rather annoying someone else did it first.
I named mine Blimpjet.
Edited by D.I.Y. Mik
i think thats the reason why my importer recommended me to go through Melbourne even though its further it was because the compliance shops in Sydney probably get a fair few cars needing compliancing. But either way two months is a bit long.
Haha dreams happen every night!
I just keep looking in the FS section for parts.
Shell I have had 2 months to get excited and now slowly the excitement is turning into depression.
On the plus side another work trip to South Africa for 3 months is coming up and I have a high chance of going.
    • Dort sounds above 3k rpm are dorty 🤣 I might krinkle black the alloy 🤔
    • It makes you wonder, all these people starting to make a billet replacement head, I wonder if any have thought about trying to adapt tech from newer engines into them. You're already at the full design stage to make a billet head... Why not really spice it up and had some more modern tech into the mix too...
    • Connect all the plumbing up properly. The actual worst part about having the turbo unable to actually build boost, is you can and likely would over soon the turbo if you drove the car (free rev while stationary isnt likely to manage it).   If you do have an air leak as Duncan suggested, you'll have a bad time as the AFM will be saying different to reality.   As you have had the engine out, I'd go over all electrical connections again. If you have a consult cable, plug it in, and see what the ECU thinks is going on. Did you touch the timing belt? If so, double check your timing on the gears is correct AND put a timing light on it while it's idling and see what ignition setting you have. Is the AFM you've installed the one that was in the car previously? You said you replaced seals, what seals exactly? What have you had apart?   From memory when I had my RB25DET with factory throttle, there was two plugs the TPS plug on the loom could go to. One would leave the car running like shit, the other made it work, I think one plug on the TPS area was for something else (an option). It's too many years since I saw that part of the loom to remember properly though.   Is the car idling smooth (as smooth as an RB can)? Does it smell fuelled up?   I have a feeling either timing in timing belt is off, or a sensor isn't right.
    • Theres still skid pan and motokhana days up in QLD at least that are $100 or less. The ones that are ran as "driver training" less so, they're expensive, but just normal skid pan days like SAU ran are still low cost. And thats one of the places I learned to be a lariken, purely by asking for passenger rides, and how people were doing crazy things. Reese gave me plenty of pointers back in the day for skid pan! And yes Duncan, I will never forget your pointers for track work. Especially after Neil got out saying "I am NEVER getting in the car with him again!" 😛
    • 49719 is the cooler loop. Right at the front, LHS of that diagram. Return line from rack (LP side) goes to cooler loop on RHS front of car, then back under engine and returns to bottom of tank. 49717M is feed from tank to pump. HP line out of pump is thick rubber, followed by the hard line that runs down to crossmember and runs in parallel (but opposite flow direction) to the LP return line. Nothing goes anywhere near the firewall or interior of car. The closest they get to that is the connections on the rack.
