The Wasteland - ACT Style
krzysiu
Body looks ok, would have to see it up close to be sure.
A nice straight shell is always worth a bit, and good to have.
Fire damage looks superficial, no real damage, weird though it looks like someone made it run again, coilpacks, blue hoses etc, no soot on them.
Well.. Today marks one year with my liner! :O and might I add, what a great year it's been. Meeting heaps of great people that also share that rb passion! :yes:
How she was when she arrived into my hands.
2a307a70-6f09-426a-8c12-850b1624e880_zps
00dc2f45-2610-4df0-803f-8bb1ada59727_zps
978867ce-aa8e-4c84-93bf-75b57ba9663d_zps
Lots of small changes along the way. It has been a lot of fun. Lot's of learning to be had and plenty more to come. It's funny how the more you learn the more you realise you really know nothing at all haha :/
I'm pretty happy with how things are panning out. Big performance mod to come in the very near future :woot:
And some plans I have that are purely cosmetic. Then hopefully the spending might slow down a little.... :whistling:
603274fe-d494-4e6f-a8ef-c50ac0ebdd1e_zps
0e6512d4-8b19-4a4d-be4f-424e4841e159_zps
d6d68bf1-e83d-4f1d-9357-04750f450903_zps
So yeah.. Thanks to guys that have helped me out over the past year!
It's been a good one and I'm looking forward to the next :D
  • Like 2
Its full of rust haha
Chop it up for panels and parts.
Couldnt agree more. Haha the sht ive wasted my time and money on...... I can only hope i know better now. :laugh:
Congrats Chris! You have changed her alot for the better in a year. Seems longer :yes: Nice Feeling though isn't it?
My 3rd Skyline Anni was the end of last year.
I bought her an Older Sister as a prezzy. :D
Wow.... i never thought about it, nearly 4 years for me, and i still feel like a newbie to skylines.
But when im working on it, i now know all of the nuts, bolts and screws. I dont have to organize them, i know where they go.
I think the variety ways to mod a Skyline make it one of the most interesting cars ive owned.
Hence the feeling that ive only had a small taste of the magic that is possible.
Man that's crazy. What's the latest news on ETA?
Latest ETA was 3 days ago.
Same as the previous ETA that was 3 weeks ago
And the ETA before that was 6 weeks ago
I think I have been given about 4-5 ETA's and all have not been met.
Huge holdup with paperwork for DOTARS from what they are saying
    • I am impressed with all this level of adjustment. I didn't expect all this possibility
    • Correct.  In the case of the 500kw dyno plot I showed you the car actually runs two boost control solenoids for boost control and a 5psi wastegate spring.  It allows me to control how much boost pressure is applied to both sides of the wastegate valve at any point and fairly accurately control boost target as a result. I've tuned it so that it's able to target anywhere from 5psi to 25psi depending on what's needed.  The target tables I've set up in that car are Gear vs RPM, so every gear has potential for a different boost (and torque) curve.   First and second gear have quite low boost targets, third gear actually has different target boost all the way through the rpm range as it's a stock RB25 gearbox - the boost targets have been chosen to maintain a peak of 600nm (what the owner has set as the maximum torque he's happy with putting through the stock 3rd gear) but it carries that to the rev limiter.   The boost curve to achieve that is something of a ramp up, then hold, then ramp up again and the power curve looks more like a flat line haha.
    • so you can decrease or increase the boost depending on the diet as you wish?     by acting on the wastegate?
    • That's torque and power, it's all from a single run.  The boost curve is "held back" from it's peak target in the 3500rpm to 5000rpm range from memory, so it ramps hard to something like 18psi then climbs more progressively to 23psi nearer 5000rpm.   It makes the torque (and power) ramp more "natural" and less hard on parts and traction, it doesn't feel artificially held back.
    • Here's the torque curves from the car I ramped boost up later in the rpm to allow a slightly wider useful power curve - the power curve is a bit weird shaped also thanks to the TVIS (or whatever they call it with the 4EFTE in this Starlet) which changes the volume of the intake manifold throughout the rpm range, but you can see that the green power curve actually holds later on with the extra boost... but looks almost more like the kind of thing you'd expect from a cam or exhaust change
