Haha I found one before and he fixed it straight away. Just sent him your one as well.
When I get back we are going to do a full detail on both of my cars and his going to write a blog post on the website called "Old meets new"
He recently won best Maserati at that Italian auto show on parliament grounds.
Pretty glad I don't post in normal wasteland anymore. Just checked out some kids build thread where all those guys were being dicks and then the mods come in and join in with filling his build thread full of shit.
The kid clearly had it coming but honestly a build thread is not the wasteland.
Yep, I just read thru the whole thread. Mostly just pricks being dicks.
He has some interesting taste in mods (Not My Cuppa) but it is HIS Taste so leave him to it I says.
After all, It is His build thread. Each to their own.
It's no wonder some longterm SAU people have a tendancy to distance themselves from it from time to time. :/
Yeah well that's the worst part of it. The guy is now never going to share his ideas or experiences again.
I love this club and I love the fact we have so many different people throwing together so many different setups. But the fact that even the mods joined in to create a wasteland of his thread is just disappointing.
I mean sex spec or what ever you want to call it is not for everyone. But it's his pride and joy which just got smashed to bits on a public forum. Also the fact he wasn't one of those guys who just joined and started to be a dick.
I'm sure threads have been cleaned up and warnings handed out for much less.
Constructive criticism is fine but there isn't much of it there. Just negative dribble and unrelated crapus.
It is disappointing.
It's in the wasteland? Well there's his first mistake... no one takes things seriously in there. I can't remember the last time I even looked in that section lol. I like off topic on forums but the wasteland is just shit.
Thanks for mentioning the thread guys, it was bullshit. Cleaned up now but it should never have had that much crap for so long.
Generally...if someone sees a thread that needs cleaning up please report it. I can't speak for all mods but I for sure don't have time to actively moderate every thread, especially ones that I am not officially a mod for.
  • Like 1
    • Haha yea it's a bit of a weird setup at the moment, just wanted to make sure I sorted out any headaches before dyno day. At the moment I've changed the exhaust manifold, turbo and downpipe, 460lph fuel pump and rising rate reg as well as the previously mentioned headstuds and gasket. The nistune was already mapped for the car as it was and drove around for a few months no worries. The plan is to run flex fuel hence the big pump, which I've wired direct to the battery through a relay to avoid voltage issues.
    • Um. Was the ECU the same as the one previously there? I know R33's needed R32 GTST ECU's or other tomfoolery to run Nistune. This is such a wild setup. Most people would plumb in the turbo then not drive the car (i.e tow it to a tuner). What's actually changed since it last ran?
    • I'm a bit stuck with this one fellas, I recently decided to undertake a turbo conversion on my GTS-4, ended up pulling the motor to replace all the seals and do an mls head gasket and arp head studs while I was at it. Everything has gone according to plan, no oil or coolant leaks, compression checked out, and decided to give it a test before I book it in for a tune As it stands right now, the turbo only has oil lines plumbed so that I don't put boost into my untuned engine, and I'm using the factory GTS-T crossover pipe with a maf and poddy as a temporary intake. The car starts with relative ease and idles amazingly, however as the title suggests it really doesn't want to rev up, runs very smooth but almost feels choked out and unresponsive to the throttle, almost like it's running lean or something? I've triple checked my vacuum lines and timing with a timing light, injectors haven't been touched as of yet to avoid flooding the engine and worked perfectly beforehand, new plugs and coilpacks, I've even unbolted the cat just to see if it spontaneously collapsed, no dice The car currently has a nistune r32 gtst ecu installed so I have no way to check for fault codes. At this point I'm a bit stumped. Is this normal behaviour for a car with a turbo bolted onto the exhaust going nowhere? I'd imagine the turbo wouldn't cause this much restriction in the exhaust without the boost going through the intake. Any ideas? If necessary I can link a video of how it responds to full throttle while in neutral.
    • Insert tab A into slot B?
    • Instructions seem simple enough to understand.....
