Thanks RoB
cost a little bit more for the print underneath and not fully sold on it yet.
But seemed a good idea at the time (Impulse buyer) :)
It's Good! Slap an SAU sticker on there and it'll all make sense. :D
my view! ..... you don't need to make sense, many people ask me what my number plate means (THE34T) ... I say, if you don't understand it, you don't need to.
What does your number plate mean? hahahahaa
True. Never understood what THEEAT is supposed to mean, unless you're a food critic? :D
In other news. ---> http://www.gumtree.com.au/s-ad/dunlop/cars-vans-utes/1996-nissan-skyline-r33-4door-sedan-gts25t-turbo-rare-/1055461545
WTF is THEEAT!! .....
And that Gumtree link wont let me in, many women have a similar policy but what's going on with that site??
(( oh I guess that's the 3=E & 4=A thing!!!)) .... never did really get that, but ok, hehehehe...
Edited by THE34T
Seriously? Woh... Tis sad :( but also a little Excite to think of the possibilities. :)
Had a Very Nice sounding V8 fang past me this arvo. I started Mentally going thru various Carsales ads I have seen recently. :woot:
  • Like 1
Ahhh I see, I sorta guessed that what it was ... a sad moment indeed mate.
Can anyone tell me the best place to buy prescription drugs online without needing a prescription..?
Wat
Good luck with that. It's not exactly legal lol
Anyone wanna buy my van? Dead serious, I'm committing to a 2014 Golf R after taking one for a spin the other day with Reece. It's up on carsales/gumtree for $16k neg, but will do 14k flat if anyone from here wants it. Or find a buyer for me and I'll give you $500...lol like that'll happen though :P
Wat
Rofl, just taking the piss out of those spamming threads on sau in the last 24 hours.
I work at Canberra hospital pharmacy so I already know where to get my stuff haha ;)
I always think "THREAT" when I see your plates lol
Wat
Ooooooh jelly! They look so good... not cheap though!
    • 49719 is the cooler loop. Right at the front, LHS of that diagram. Return line from rack (LP side) goes to cooler loop on RHS front of car, then back under engine and returns to bottom of tank. 49717M is feed from tank to pump. HP line out of pump is thick rubber, followed by the hard line that runs down to crossmember and runs in parallel (but opposite flow direction) to the LP return line. Nothing goes anywhere near the firewall or interior of car. The closest they get to that is the connections on the rack.
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
    • Don't worry about. Just don't try to drive hard enough to make boost and you'll be fine.
    • Yes. This has already been said. It is a loop of hardline in front of the radiator. Because.... the pump is on the LHS and the steering rack hydraulic connections are where they always are on a RHD steering rack....on the RHS. The high pressure line goes down under the engine, along the crossmember, like it does on all Skylines. Don't just throw expensive braided hoses/other kits at it. Work out what is wrong and fix that.
    • Still got the afm on the intake, clamps are shut tight, only loose hose is the one that goes from the j pipe towards the IACV, since it's next to impossible to find a factory hose and the barbs are different sizes (I'm still using clamps on this hose to try and help it seal on the iacv side) I've ordered parts to make up the hotside of the intercooler pipes, I'll plumb it in and see what happens in a few days I suppose The turbo's internally gated, can I just unscrew the tension rod to let the gate open?
