haha you are such a newbie beau 130+kb's is shit for the plan you are on plus your latency is quiet high you must be a fair ways from the exchange. Do what i say and go to the microsoft website and download something you will be gauranteed that there bandwidth will be greater than yours.
your on crack
P.S. i checked Line configuration on bigpond site, there were 2 options, standard or fast
Difference between them was:
Standard -
Noise Margin: 6dB
Interleaving: ON
Fast -
Noise Margin: 6dB
Interleaving: OFF
It said Fast could incure dropouts etc... but would be faster data transfer or something... i guess ill see what happens?
Edited by SKYLVIA
This should settle it :blink:
"CompuServe used to distribute a graphics display program called CompuShow. In the documentation for version 8.33 in the FAQ section, it states:
The GIF (Graphics Interchange Format), pronounced "JIF", was designed by CompuServe and the official specification released in June of 1987. "
Google delivers.
Gif as in Gift for sure!!! I dont care what google says :P
sif you'd say Jif... it's a G not a J!!!
do you go around saying Jolf instead of Golf or Jiggle instead of Giggle or Jet the f**k out instead of Get the f**k out... should I keep going??
    • Yes, but it's not as easy as pulling a fuse on anything other than an R32. There's a routine you have to do, involving disconnecting a loom plug and bleeding down the preload.
    • A question for tuning awd, is it possible to disable the AWD? The stagea is an EA/T AWD, Toshi had said on a GTR, he was able to disable it and make it 2wd. Just wanted to double check if this was possible
    • Whoa, that's a name I've not see for a long time! Sorry to hear about the engine / turbo damage.  Fwiw with any engine problems it often really a case of just seeing what happens when it's apart, ymmv - I wouldn't rule out the possibility that the damage isn't even from the turbo failure, or possibly from a combination.  The airflow between cylinders isn't dead even, injectors can go off over time as well, with the turbos overboosting if you didn't have upgraded fuel system there could have possibly been a bit of leaning out - stock triggering is often a bit unreliable by this age too.  Basically its an old engine and a few things could have been going on, and you won't know how much work is needed until the engine is apart.
    • I'm just shocked there's a euro driver on our roads who is thinking of other road users and not attempting to blind everyone. I wonder if Prank uses his indicator too...
    • Its hard to tell really. The Q50 owner's forum talks about it a lot and has quite a few people directly affected, but no idea what % of cars sold actually had the block replaced. Also, there seem to be 2 distinct issues which both get diagnosed by Infiniti as requiring a block replacement (no wonder they are going broke) 1. "Porous block" where coolant mixes with oil through thin or poorly cast parts of the block 2. Head coolant gallery plugs not sealing. If I was noticing engine coolant loss I'd start with cooling system pressure test (as always) and then I'd pull the cam covers and reseal the coolant gallery plugs on both side before worrying about a potentially porous block.  If neither of those did the trick it would be put in a second hand engine out of japan; I haven't checked pricing but I'm sure there are plenty around by now as they've been in production 10+ years
