today is my birthday. anyone who does not wish me a happy birthday will be banned.
Shell :)
HAPPY BIRTHDAY SHELLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLYYYYYYYYYYYYYYYYYY hope your day was not to bad and got the chance to have a few brewski's :rant:
Cheers,
Leigh
I dude at work got a Toyota GT4 and it got a water to air intercooler do any other cars have this seems a bit stupid
Older Liberty's have em, many AM companies sell em. Popular in rota drag circles, and with horsepower dyno queens.
Why you say stupid? They have their place for sure. Can keep intake tracks a lot shorter; improve throttle response etc, then mount the radiators for it where ever you want.
The setup has a buffer too, so you don't get the same level of heat soak, that air->air IC has in stand still traffic.
Happy BirthDay Shell :rant:
Also, memo to leigh, quotes are supposed to go before posts.
i always do it that way in PM's, but not on the forum... dunno why :rant:
thanks leigh & michael :)
I had a fantastic day, much better than last years birthday which sucked.
and yes leigh I've managed a couple of bevvies :)
Happy BirthDay Shell :thumbsup:
I was just think that a contain of water sitting on top of the engine is i dont know like a rice cooker , what about when it is full cold do air to air work better
Hey Rick444 I'm with you re gettin out of that workshop .... but I am interested, does the intercooler on a stock 33 make a big difference? I'm not racing, drifting, draging etc - but am interested, is it a worthwhile thing to do?
It doesn't really make a huge difference, but my car feels better after putting it on, more responsive..it's hard to explain...
I would say it's definitely worth it, especially if you're planning to do more mods. :thumbsup:
HAPPY BELATED BIRTHDAY SHELL!!
BTW, it would be nice if crime took a day off. Imagine if you could leave your car unlocked and go shopping and come back to an untainted car: nothing stolen and no scratches/damage.
Ha Ha as if that could ever happen.
Put the crack pipe down :P
Magine a box welded around a normal air->air IC, and then water pumped through that box, through and around the fins, and then to a radiator(s) [ Separate to the engine radiator clearly]
Your just replacing the air that was moving through the air->air cooler fins, absorbing heat, with water... which then releases its heat to the air, when it gets to the little radiators
haha there was no intension of that leigh, which is lucky cause shes pretty much a grandma :domokun:
pretty weird, only 3 movies ive been keen to see recently (300, spiderman 3 and 28 weeks later) are all ones youve posted about skylvia. Do they tell you anything about the main characters from the first one in the new one (james and selena?)
Edited by Baconer
havent seen spiderman 3... i heard its a tad dissapointing...
Nah nothing about the original 2, but it starts at the 28 days later timeline, then shows how it progressed through to 28 weeks later. much better than the 1st IMO. the 1st one was still good tho
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
