Optus had a major outage in brisbane, maybe a cause of some issues, a lot of pissed off customers.
yeh I heard about that, sux to be them!
well I think I've fixed my problem anyway, turned phone off and on, and little symbol that means it's still trying to send the msg (which has been there ALL afternoon) has disappeared so I guess it went.
last time go around to michele's house and use her internet.
That wasn't my computer... it was Marks :banana: but I do remember warning you what would happen if you forgot to log out LOL
You can blame Mark for what happened LOL it was his idea.
you have way too much time on your hands.. and too many action figures :D
LoL, not mine. Its from the 2nd page of a google results with moderate filtering.
... my doll setups are fluro haired trolls on a barbie :D
Edited by GeeTR
BUmp buMp bumP
Anyone a MMA fan? catch affliction last Sunday?
My god, didn't Tim get smacked the f_ck down??? Check YT for the links if you missed it. Arlovski and Ben Rothwell was the best match lol Arlovski IS sparta
Fedor 4 eva
Edited by GeeTR
    • Nah it factory manual not sure about ratio but it looks like there’s been some work at the rear
    • so I need a new speedo cable
    • Throwing my spoon to the soup here a bit.  When I installed a 044 back in 2012, along with the direct power mod, the car became very difficult to start. To a point I burned one starter motor as I was late for work and tried to get the thing going. With some tuning and careful use of gas pedal when cranking it became bearable. Trying to make this short as possible, but the 044 died after 2-3 years, after which I went with an AEM 320lph pump, which also died after about 4 years to my dismay. After that I went with a Nismo pump, and while trying diagnose an emissions problem, I noticed for the first time that my fuel pressure was 5bar/72psi on idle, and that removing the vacuum line did nothing. After monitoring the situation, and removing the direct power feed and going back to FPCM in attempts to remedy it, I noticed there was fuel in the pressure regulator vac line. Kept the FPCM, installed AEM external regu and the car became sooo much better in every way, including starting. And I had driven it like it was for 11 years.. Anyway, I agree these are likely two different problems, and the FP problem you just haven't noticed before. I do not know much about haltecs, but what first came to mind was the CAS, which probably is not there any more. So how is the wiring from haltec to gauge cluster? How is the battery voltage and alternator?
    • Your car was auto before? You have different diff ratio (auto vs manual i think? or n/a and turbo?)
    • +1 for getting a screen off alibaba, CarPlay/Android Auto is vastly better than whatever navigation cars had 10 years ago. I got an Android screen for my 2015 BMW, huge difference. Fully compatible with factory stuff including iDrive controls.
