haha it rippled across from Un Zud :D
it really pissed me off cos it was only a few seconds but just enough to f**k up everything in the house :D And I was trying to sleep dammit, things beeping and turning on and off didn't help!
my friend in swinger hill said the same thing happened to him the other day too
  • 3 weeks later...
So... I've been off work a week and got rather bored:
Do, or do not.
3PO
Riiiipleeeeeey!
Stay on his tail Red 4!
Slave I
Nay...
Watch out Steve
It's a vegesaurus!
Supposed to be an ant. Looks more like something out of Starship Troopers to me ;)
Orca
For 20 points, movie I saw when I was a kid. *** and the Hound
According to prison break, this is a 'crane'
Where's Chief Brody!
Um yeah. I was REALLY bored. More angles and stuff in my gallery HERE if you're also bored.
Edited by sl33py
woot! Trackside is on today!!
sooooo f**king excited!!!
THE LIVING END
GYROSCOPE
CUT COPY
THE PANICS
BLISS n ESO
BRITISH INDIA
SOMETHING WITH NUMBERS
THE GETAWAY PLAN
SPARKADIA
MUPH n PLUTONIC
CARPATHIAN
BLUEJUICE
GRAFTON PRIMARY
LITTLE RED
LOS CAPITANES
HANCOCK BASEMENT (triple j Unearthed Competition winner)
THE LIVING END
GYROSCOPE
CUT COPY
THE PANICS
BLISS n ESO
BRITISH INDIA
THE GETAWAY PLAN
SPARKADIA
MUPH n PLUTONIC
CARPATHIAN
BLUEJUICE
GRAFTON PRIMARY
LITTLE RED
LOS CAPITANES
hehe, this band was started by some of the guys in my year at school.. good to see that they appear to be doing well
were they any good shell, ive seen them play a couple times and they have been really good, they use brass instruments as well as the generic band instruments (drums, guitar etc)
I didn't see them :( they were probably on early with the other lesser known bands and stuff... I didnt bother going till later in the arvo
I'm pretty sure I've heard them before though, on JJJ, I do know the name!
    • Yeah one of the first things I out in when I started having catch can filling up issues. Still prefer to empty 1-2 times a track day rather than every session
    • You'll find this link is probably more useful  Performance Turbochargers - Garrett - G GT GTX GTW Series Turbo TBG G35 1150 map may not even get added to my list depending on how it looks, the G35 1050 already is a mixed bag for making the numbers you would expect from the compressor map due to mismatch - I don't know how another 10lb/min of compressor flow is going to make that any better.   I've left out others for similar reasons as it's already getting quite big.   In terms of Precision, provide me with legit compressor maps for them and I'll do my thing   I'll add some more of the newer Xona Rotor options are they're pretty boss, I'd take a 68mm Xona over a G35 "1150" any day of the week - or Precision for that matter.
    • Ahh got it. Well maybe install a drain for the catch can somewhere down low and accessible like a wheel well too....
    • Before you blow your car up, have you checked you've made all the correct modifications to the wiring if you're still using the RB20DE loom?   Some things to look at: The pin used for the map sensor on the RB25DET, is the same pin used on the RB20DE for the Ring Gear Crankshaft Position Sensor, no idea what you've got it plugged into now. The turbo pressure control valve solenoid you're talking about on the RB25DET, the same pin is used for the Variable Air Intake Control Valve on the RB20DE.   The factory manual has the wiring pinouts in it for you to check everything. It also has the diagnostics process to read codes out. In addition, there's a great table that shows what sensors and what actuators not functioning will relate to which signals. And Nissan confirm the as everyone else has from experience, the Solenoid being disconnected won't cause a fuel cut. However, the turbo pressure sensor being missing / wrong, WILL cause a fuel cut. https://www.nicoclub.com/service-manual?fsm=Skyline%2FR34-Workshop-Manual-English.pdf
    • I've been hunting info on the G Series II - this is best I have found so far(Link below). Still waiting on the G35-1150 comp map, kind of very keen   So how do we go about getting precision on that little table of yours ?   https://turbosbytm.com/sites/default/files/product/technical-info/Garrett-G-Series-II-Product_Flyer 25 30 35_1.pdf
