It's a camera that will register when you are at the Hospital and then again at the Monaro Hwy..... if you were not doing 80kms the whole way between the points, it will know, cos you got there too fast :happy: Then you get booked.
Its just going to make everyone super paranoid and drive at 70.. thus making the traffic problems worse in peak hour. It will also cause alot more road rage as there is nothing more frustrating than someone driving UNDER the posted speed limit infront of you
will also most likely increase accidents as everyone is paying attention to how fast they are going not the traffic around them.
Yeah it's vehicle recognition. It sees your car, remembers what it looks like, then picks it again at the next camera. It works out your average speed between the 2 points based on how far they are apart and how long it took you to get there, and books you if you exceeded the limit.
That being said, if it takes you 20 minutes to travel between them at the speed limit, you could stop for 10 minutes after passing the first one, then double the speed limit (160km/h in this case) the whole way there, and not get booked by this system.
True enough Troy lol. But they'll prob still have regular cops driving around :happy:
Yeh sounds in someways like a good idea, but in others, like something to create more issues.
Does the sydney toll roads work like this - the ones where you use etags etc... cos if it doesn't, surprised they've not implemented it already. They know when you enter, when you exit and how long it took between each point.
This sounds like a less than fun idea. Prob also is, say you average 3-5km's over, normally wouldn't get booked for that, but over the length of a long road, that saved a noticeable bit of time - they are gonna book you for that...
If it checks you at the Hospital then again at the Monaro Hwy you can just speed all the way then turn off before the next camera and take back roads... point to point average speed cameras only really work if there is no where to turn off between the cameras
Thus my point re the toll roads in sydney, they already register when you enter and exit.
But yeah does only work if there are no turn offs. But they could do it between two sets of intersections. EG parkway they could do one between lady denman drive and cotter road had they wanted to.
yup, or even sitting on 80km on that stretch where there's 3 lanes going from the hospital up the hill will be a PITA. If you don't use it much then you just just deal with it, but not every single fcking day... staring at your speedo all the way to work.
I'll probably go via the Monaro instead.
They are also doing this without fixed cameras in sydney or atleast talking about it. they mark a measured distance in the road and time you with someone in a plane overhead, so not only do you need to look out for cameras, you also need to be looking in the sky for the pricks with their stopwatches. although it is a big white line across the road so if you cross one slow down untill you cross another. i think it is being trialed on the F3 at the mo
I saw the signs for that last time was up sydney way.
... which is doing speed while ur speeding with speed stripes on ya car!
dont mind me, i get stupid when im bored. wait - no ones allowed to 'fix' that statement, or i'll get my mum on ya.
wait, what am i saying now!!!
damn it, dont push add reply....dam
Australia doesn't really have the population for this to work full time.
In the states they do it in remote areas like bumf**kville on the highways to catch the country drivers who go out there to.....enthusiastically drive their vehicles.
Anyway my point is SPEED KILLS!! OH WON'T SOMEONE PLEASE THINK OF THE WHALES!
If I can't fix it can I repair it?
speed has never killed anyone. its the sudden stop that does it.
This is purely without a doubt just a revenue raiser. Even one of the top traffic camera office guys thinks it's shit.
Also what they have done is taken all of the money out of maintaining the existing red light speed camera program to get this point to point thing going... Cough cough, red light speed cameras at the moment are lacking maintenance...
at least i usually only travel past the point to point one in my van, which is lucky to do 70 up the hill.
    • The max they would go for me is 50.
    • That cannot have been a fun set of drilling. The stock "baffle" looks identical to rb26, I just cut fuel cell foam to fit the full length under the baffle.
    • I understand your sarcastic exasperation. But to be fair - the baffles do indeed fit OEM cam covers. They did omit to say that you need to do a bunch of stuff. But they do fit them.
    • Got started on the modification to make these splash plates fit over the long weekend. First the surprisingly time consuming task of swapping all the cam cap bolts to Tomei cam cap studs. I did the method of removing one bolt at a time, applying loctite to the stud, double nutting to torque as the manual described. Then carefully unlocking the nuts without disrupting the torque of the stud (and going back to re-torque a few times when it slipped). Finally applying the nut and torquing to spec. Repeat x28 Next up I went about removing the stock cam cover baffle so I could ensure it was fully clean after drilling for stud clearance.  As the blind rivets holding the baffle on were domed I used a punch to mark the center then used 4mm drill bit to carefully drill out the rivet without going too far part the baffle. As seen in other thread here is what is inside the stock baffles I decided on M4x6mm bolts to bolt the baffle plate back on with. I used a 3.3mm drill bit with some tape to mark the depth at ~8mm. Next was to tap the threads using a cheap bunnings kit M4x0.7. With the baffle removed I also drilled out the spot welds holding in the baffle plate oil returns. Unsure whether this was the best option or if I should have cut holes in the Hypertune splash plates to allow the oil drains to still function... time will tell. I then removed the the Hypertune splash plates so I could rest the cam cover on top and use a dab of grease to mark where the studs impacted the oem cam cover baffle. The most obvious spot was on the hump from the stock mesh is held. Using this hole as an anchor I bolted the oem baffle plate back into the cam cover and lined up the Hypertune splash plate. Marked the rest of the holes for the studs and drill those out too. Total 32 holes drilled and 12 threads tapped on the passenger side cam cover alone for this bolt on part that totally clears all OEM cam covers.. Drivers side next as well as some E85 safe fuel foam to fill the space behind the behind cam cover baffle plates. oh and some lock nuts for the splash plates of course.
