f**king australia day.
Some bogan came in the wrong way into the servo and took the only available diesel pump, when heaps of other ones are free, so I do a little head shake to myself.
He starts swearing at me and carrying on. By thus time the only other diesel pump frees up and I turn around and have to reverse in.
So he comes out from paying, goes to get in his car, gets back out again and pulls a flick up to my throat and says "you better be carefull who you shake your head at, cos next time I'll jump through the glass and skull f**k ya. You'll f**king die on australia day." Points to his head and goes "don't f**k with skin heads" or some shit.
f**k it really brings out the best in people doesn't it!
$#!% that's in ur face scary shit.
There's F>A you can do in that situation.
The freaks need a bullet to the head!
Don't stress Karma will deal with that oxygen theif.
He'll end up injecting a bad hit and die frothing at the mouth :thumbsup:
C**T!!!! I would have been angry enough and stupid enough to be a downright bitch to him if he did that to me... No common sense or self preservation levels, would have landed me in trouble lol....
Good work for staying calm! :thumbsup:
Damn that is some messed up schitt. ow dodgy and UN-AUSTRALIAN!
Glad you got out of that one alright. I take it the service assistant ang every one else didnt see? And thus it was not reported? I guess that is a little risky in itself....
