Yeah got access to an engine hoist.
Basically I just need to remove the oil filter housing, install the sandwhich plate and put the food feel line on. The joys of an engine conversion nobody has done before, you learn the hard way. :)
Skillset?
I'm awesome & shit... nah, reception mainly but i've done retail work & worked in the public service as well.
Check the wasteland for skill set... :troll:
Lol that'd be a good resume, just get all my posts into a Word doc.
Any chance SAU can put down some music on their website ? Mayhaps link something via windows media playa to one of the Internet radio stations huh huh huh....
I'd rather listen to my own stuff.
Prue, I'll find out what this posi will be paying and get back to you if you want. Located in Tuggers.
Edited by MIVEC
Prue you should try to find yourself an EA position in a public service org like Centrelink/DHS/Medicare. You'd almost certainly be located here in tuggers, and it's practically a glorified secretary :P that, and you'd be hard-pressed to even find one lower than APS4
