Anyone going to the SAU Nationals in Shep ?
I just booked a 2 bdrm twin room apartment that can either have a King size in each room or 2 x single beds in each room.
I would like to share the $295 a night cost. ($150 each).
Yeah sounds exy but hey FTW. If your interested contact me quickly :cheers:
Secure undercover parking :D
Facilitiestick.gif Fax Facilities Microwave Air Conditioning Freezer No Pets Austar Fridge Non-Smoking Establishment Bath Fully Equipped kitchen Non-Smoking Indoors Breakfast Available Gymnasium Off Street Parking Carpark Heating Office Services Clock Radio Highchair Available Phone Clothes Dryer Internet/WiFi Quiet Conference Facilities Iron/ Ironing Board Room ServiceCooking Facilities Kitchenette Safety Deposit Box Cot Available Laundry Facilities Tea/Coffee Facilities Disabled Access Linen Provided Television DVD Player Lounge Toaster Family Rooms Massuer on request Toilet
Edited by Sinista32
So the roof is a low 2m high.
I think the top of the 8*4 pool table sits at around 900mm height.
Should i install:
6 downlights (one basically above each pocket)?
4 downlights (one above each edge lengthways)?
3 downlights (in a line going down the center of the table)?
Thoughts?
Should i install:
Thoughts?
I think you need one of the proper roof hanging lights still, they look classy and are nice.. So the long box with 2 fluro tubes.
Downlights are too direct and will not give you a smooth light coverage. Your roof may be low but no one will be walking under the light where the table is, and when you shoot you are leaning over the table, so even if the light takes up 30-50cm from the roof, you have 1.5m clearance from the floor and still enough height to play.
If the traditional box is just gonna be coo much of a space hog, at least go for lights that diffuse well and spread an even light over the table, and i recommend the three down the middle personally.
I have a box that I used to use with it. It's still a consideration. But the roof really is extremely low... Even if I mount it directly to the roof without hanging, I'm worried about it being too low and being a head hitting hazard, also worried that it won't throw the light to the far edges of the table.
If I use 6 lights quite close together there shouldn't be too much of a spottedness pattern I'm thinking.
+1 for peoples opinions
I asked a few guys from work, They all seem to like them so I bought a set. $120 for 42 spanners. They look pretty good to me. and have thin heads on them for getting into pain in the ass places. I think I did well
    • In all the track days I've done over the past few months I've only had 1 issue with braking and thats with my current EBC pads (can't remember the colour, but they're not a track pad). I don't *think* I have had issues with brake fluid getting too hot, my understanding is that when that happens you will have quite noticeable brake loss - which I haven't had.  I'm using just regular ol' Penrite Super DOT4 fluid. I use this fluid in everything and my cars always seem to stop so I see no reason to change, except ... for the 335i. I need to do a fluid flush and was thinking about my fluid of choice and wondering if I should consider using something more high temp? Its not a super fast car by any standards but I'd hate to do a flush and then find myself with no brakes when I get. to Wakefield.  I guess, my question can be summed up as "How fast do you need to be driving to need higher temp brake fluid?"  I remember high temp fluid was considered a must have back in the day when I had my GTR.
    • For anyone that comes here looking for answers on what can go wrong with gts-4 to rb25detneo swap. The Gloria's awd sump is different and does not fit. The rb25neo from stagea are exactly the same sump bolt pattern and axel alignment. Castings numbers are different on Gloria's blocks and oilpans if they need to be identified.
    • I have information on this for anyone that comes looking again. https://www.facebook.com/share/p/18gsbFaYTU/ The rb25det neo from the stagea has the same sumo as rb26 and r32 gts4 (and other awd models). The sump that has caused so many problems during swaps are from the awd neo Gloria's. The casting numbers on the block and oil pans are different so this may help identify if you can't confirm where the motor came from
    • Not feasible to fix the boot lid you had? Damage looked minor/hard to even see :p Source: Drove into something recently and you should be happy you didn't!
    • Another new used boot arrived at the painters, it was sent back as there was nearly as much damage as the original one I want to replace  Finding a clean used boot lid is proving problematic, and I'm not keen on dropping $1500 on a new one from Mazda Sigh....
