Thats pretty much it, if you have bad luck and get done for defects, its tricky to get out of it with your mortgage intact.
Ive always lived here, when you dont have to pass the car every year, it gets more modified.
Ive had vehicles registered that go 260kph but so crap the exhaust falls off, its weird putting z rated tires on a shitbox.
However being a tradie i drive a ute every day(more mods) and dont seem to attract their attention.
Troy if your totally legal and everything engineered, thats hard to get, be proud. And enjoy peace of mind.
by the way 2 anchor points? did you get twins? that would be cool. :thumbsup:
haha yeah 2 anchor points. He did it so 'by the book' that he checks the vehicle plate to see if it's a 4 seater (2 points) or a 5 seater (3 points).
That's exactly it too, it will be entirely engineered except for when I put my exhaust ant BOV back on, which have never given me troubles anyway. Other than those 2 things, nothing about how the car sits right now is defectable.
Goodbye old faithful.
The ute is sold, had her for about 10 years, many great memories, like drifting on the dirt, in the dark, snowing, all the way to Adaminaby.
And hauling the bikes up to the brindies on those crisp, clear winter mornings.
However all the proceeds are going into the Skyline.
So funds to get ready for SAU nats in november.
Cosmetics or mechanicals... hmm.
Alrighty. Booked into Dickson tomorrow for what SHOULD be the final inspection. Everything they failed me on for this current roadworthy has been rectified, so logic says I have nothing at all to worry about as it will pass.
THE SUSPENSE IS KILLING ME!
Fingers crossed for ya Troy, dicksons new thing is getting a different inspector the second or third time around and they deside to look for more that was missed on intial inspection to out do the other inspector and big note themselves, kind of a "so and so missed this and this, I have to do his job because he can't do it properly". Happened to 2 mates in the last few months.
f**king hell. I'll near on kill someone if this happens.
EDIT: actually come to think of it, they did do this in a way...the second time I went through there wasn't on the same roadworthy, but I had fixed everything they failed the first time....however this time they picked up on the rear window tint, hole in boot floor and child restraints.
Shouldn't they ONLY check that I fixed the things I was previously failed for? Or is that too logical? lol
There's only 2 more things that I can possibly fathom they can still fail me on, one of which they were trying to determine last time but couldn't see it well enough to conclusively pick on it.
So how much has it cost you all up to get your car engineered?
Well it's hard to put a figure on it precisely...So we'll go with somewhere over $2500 inclusive of fabricating and fitting child restraints.
So without the child restraints it is considerably less.
What mods did you get engineered? Turbo, coilovers, wheels, fmic come to mind but was there much else they had to do?
Well the report covers the whole car - ie you can't ask him to engineer your coilovers while ignoring an engine swap or something. The report itself came in at $1350 ish, though a small part of this is due to having to fix a few things up then pay for reassessment of said things.
The scope of modifications covered in my ORIGINAL report are coilovers, rear camber arms, rear traction rod, HICAS lock bar, non-standard wheels, steering wheel (lol), brake lines, and turbo. There's also sundry additions like FMIC, dash gauges, pod filter inside cold air box, and oil catch can.
    • 2 more things I have to work out Easy one first...can anyone describe how to pull the fuel pump and sender from a 33? I can feel there is some sort of mount and clips but don't have a manual and don't know the trick......if not I'll spend some quality time in the boot witha lighter tomorrow. Second question is harder.  He had changed the upper plenum to a plazmaman but clearly got to a point with the vacuum hoses where he said "f**k it, I'm going inside for a beer" and never came back to that job because it was a mess. Am I right to think that I need: 1. Pre throttle (16mm nipple on inlet) to AAC's main 20mm fitting as the main pre throttle feed 2. ACC has a second 13m outlet joined to that 20mm fitting which I think is the pre throttle air supply for the cold start valve? 3. Cold start valve's outlet fitting then goes to Plenum (to bypass throttle?) There is some adapter on the back of the ACC with 2 fittings (13mm and 10mm), do I run the 10mm through a 1 way valve to the Brake Booster (4) and the 13mm back to a 13mm nipple on the Plenum as the Idle control (5)? 6. Run a 6mm vacuum line from the Turbosmart BOV to the Plenum? 7. Run a 5mm vacuum line from the Fuel Pressure Reg to the Plenum? 8. Run a 5mm vacuum line from the Turbosmart Boost controller to the Plenum? (Wastegate already has a pre turbo pressure source running to the solenoid then the wastegate on the other side of the bay)  Any help appreciated, the GTR is quite different setup and while the Stagea also has FFP it is different again. (And no Dose, I'm not pissing it all off and putting a ethrottle on it....)
    • OK, onto some questions to try and speed up the process a little. Does anyone know what core this Garret is? I know it is a high flowed standard turbo but nothing else about it. Tag says OK 0169J - 446179-5032 Same question for the injectors, I don't know what they flow and ideally can work it out before it hits the dyno, they are a mustard yellow side feed
    • Quick side trip into the engine externals, alternator and PS were in place including tensioned belts, but the PS was dry (my guess is he had the steering rack reco-ed). Filled it up with Transmax Z but it will need more bleeding once the engine is running no doubt. BTW I've said before, I don't know what kind of soft animals you have in the city, but out here they breed the rats tough. I bet they were disappointed when they tasted synthetic ATF.... Coilpacks are Splitfires with a factory loom in reasonable condition. I didn't pull one put I bet the spark plugs are new as its a new engine
    • Onto intake pressure test. I have a Raceworks (damn brand thieves!) pressure test adapter that lets you apply pressure through a standard tyre valve and comes with a pressure gauge.....I just blocked off the other end immediately before the throttle body. Applied 30psi....and the turbo intake immediately popped off with a bang. Sorted that but it was still leaking, turns out there is a pinhole leak at the BOV adapter that I'll have to find a local place to TIG up. I'm sure it makes SFA difference with such a small leak but I want it to be right. Everything else up to the throttle body was good. Also cleaned and oiled the KNX cone filter, and this is the AFM if anyone can identify it (car runs a PowerFC)
    • I'll send you a message, but until I know what is OK (and anything that isn't) its kind of hard to work out a fair price. BTW I'm just helping out here, ultimately it is Mel's call what she accepts but I know it will go sooner or later.
