Personally I don't
Brand spankers - $4000 without rubber. If you can locate newies.
Every so often they will do a run if the numbers are there.
I bought my 18 x 9.5 +12's for $4k last year.
Ones above have been resprayed.
You would need to see each one to check for gutter rash
no longer have the original Nismo stickers
the front one looks concave and the one in the back looks different (maybe optical illusion)
I think you can do better.
There was a silvers set up for sale recently that I believe is cheaper (if not sold). To suit GTT offset
Edited by Sinista32
how f**king poorly do your gutters deal with a bit of rain? Lakes everywhere tonight!
Probly a combo of not much rain lately (so not soaking in well yet) and all the leaves having fallen off and blocking things up.
I went through a puddle this arvo that would've been a good 15 meters long, trying to drag me into the gutter. (left side only).
Fight it and floor it. :D
  • Like 1
So, I have been invited by family to attend a "track day". To bring our cars out and "race" them around the track. Now, since this is a invite I can reject or decline - my main concerns are if I bring my car to the track I risk blowing something (Rosie is my daily). Once you see the line up - you'll soon discover an easy option for "you got no chance", however, since it's family it's more a fun thing and bringing the performance cars out in the family. Once you see the line up - you'll know I'm the baby out of the 4.
So the lineup for the day:
Uncle #1 Holden Monaro CV8-Z
His son; cousin - RX7 - Bathurst addition.
Uncle #2 Porsche 911 Turbo.
adv7.1_automotive_connoisseur_adv1_wheel
Me: R34 GTT
So yeah, no chance at all for me to even compete but I'd like to go out there and have a fun day,
but is it worth risking a breakage? (Are track days amazingly fun that even if you break something you're still on a high etc)
Do many things break when taking your car around a track?
anything I can do to prepare Rosie for as safe as possible run?
How many lap should I do before I start to retire the old lady?
lol who?
firstly you can beat all of them (except probably the porker), especially if you can borrow a set of semi slicks :)
seriously though....assuming the car is in good condition, do an oil change, have the brakes bled and keep the boost turned down, you'll have a ball.
I ran my old gtst (standard boost) at track days for years without any mechanical issues. Its only when you modify them that you have troubles.
# of laps are easy...keep going until the brakes fade or the water starts to get hot :)
  • Like 1
I don't know the RX-7 is twin turb AWD and the Monaro.. well I dunno - maybe in the corners :P
Anyways - semi slicks is a nice idea :) Sounds as if Rosie is going to live through it if I decide to go down. Boost is set to 10 PSI (low enough i hope) and everything else seems fine - might do a a quick service before I "track" ;) down. Thanks for the tips :)
    • Unfortunately haven’t taken pics yet after it was finished. All the edges are hemmed nicely, just had to cut holes for the gear shifter and seat bolts and seat belt bolts in the rear. The molds seem like they’re done with steam and a layer of glue on the underside to hold a bit of shape but still soft enough that it’s a good fit when it’s all pressed down.
    • When's the rear mounted turbo kit coming? Needs dose and V8 chop idle lol.
    • I was very unimpressed with how the car came up from the A pillar forward, before I hit things (twice). It all has to go. It had to go, but now it has to go... more. So we finally found the very first Shennanigans with the entirely perfectly setup engine that had no problems being pulled apart to improve on 'was perfectly fine'. Cam bearings looked a bit... stock. Which isn't entirely bad given they were stock and this is a ~20 year old engine. So new cam bearings are on the way because it's somewhat difficult to get to this stage to do it later, and it will trash the block. It was quite unusual that it wasn't done when the perfectly new-looking VCM cam was originally installed by [unknown] What IS unusual is the cam that was installed there was advanced SIX degrees. As to why there is no way to know.. however it could have been @Dose Pipe Sutututu's mate who wanted a larger cam sound but also wanted it to come on earlier to be more usable. This is my dyno sheet with the previous setup - This cam is not supposed to peak until 7000+ RPM, according to VCM. This is what lead me down the whole 'my heads/intake setup is running out of puff and can't support the cam' line of thinking to begin with. Anyway too late now - New cam is in! It could be rather funny if this smaller cam acts like a larger cam because it isn't advanced six degrees. In the spirit of everything is working amazingly - the COMP cam required no dialling in whatsoever. It was about 0.5 degrees advanced, which seems pretty bang on. Any adjustment either way would be further out. I'm told as a chain breaks in it ends up regarding back about 0.5 a degree as the chain breaks in, making it bang on. In the spirit of everything was previously working amazingly - The timing gear that was taken out turned out to be was an N-Motion double timing chain kit, with adjustable cam gear (which is how it was 6 degrees advanced) and all looks entirely perfectly new. It also had a Torrington bearing, which was one of the reasons I ended up getting the Cloyes kit which they used in the C5R 24 hour racecar - Because I couldn't confirm what was in the engine when talking to Tony Mamo. I did believe however it was a Double chain kit of some kind... but found no supporting documentation or evidence for it.
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
