bluebirds are cool, esp the weird jap models. But then I like pulsars too. actually I like pretty much everything Nissan has ever built; except tiida of course there was no redeeming feature in that car.
zeb are you coming back to the world of cool? I'd be a bit worried about this, sounds they modified it all the time "Last Modified 15/07/2013"
Before I bought the first one (White), I test drove an Auto SSS Attesa Awd Turbo SR20. It was Quite amazing. :woot:
I personally have nothing against Pulsars other than they're like assholes, Everyone Has one!
and WTF was the whole Tiida thing anyway? and now the Pulsar is back! :wacko: but the newies are nice. Big but nice.
dumb f**king nissrenault idea. kind of like the m35 :rofl2:
I don't know of any good gtrs for sale, although I do know where to get an excellent cube.
honestly, if you are not in a rush you can just never beat importing yourself for value. even with the yen off 10% from 3 months ago when I bought the cima, it is still soooo cheap for what you get
haha I want the march too. it's been off the road too long but it is still not next off the blocks
1. get ute out of garage
2. get race car running....needs clutch unwelded from flywheel and an engine swap (current one runs great but has crack in block near water pump that needs welding)
3. get stagea reverse lights and knock sensors working...it has some electrical challenges from the rb30 swap
4. finish march motor and get it running again
too many projects
A tidy GTR you seek?
http://www.carsales.com.au/private/details/Nissan-Skyline-2002/SSE-AD-2046295/?Cr=1&sdmvc=1
There we go ! :P
ahh farking internet knows everything! I thought that feature was broken. It's really just a reminder I am getting too damn old (and grumpy)
Anyway, thanks :) ....and now off to dinner
Bahahaha!!
I never even look usually, saw it by accident :D
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
    • It seems you'd like your Skyline to go to a great home, that can keep it as a beautiful museum piece.  I feel I can provide the perfect place for it, however, I'm not sure I can justify so much money for a Skyline that has only been crashed 3 times. Due to this and market prices, would you be against me buying it for $100.00, with $60 to be paid upfront, and the remaining $40 to be paid annually in equal payments?
    • I did say no low balling (Insert copy and paste article from Motor mag with complete history of R32 GTR development and racing history here)
