Yeah my partner is in love with him haha. we went and saw pacific rim the other night. Good movie. Has Jax and Clay in it as well. I can't wait until the new season of Sons.
I watch both!
Mmmm Jax....
Does it whistle exclusively while in positive manifold pressure? Or will it do it if you wind it out through the rev range without hitting boost?
If the latter, it's potentially a gasket leak on the exhaust side - particularly if it gets WORSE with boost (suggests pre-turbo, either manifold or turbo flange). If it still does it off boost, but doesn't worsen on boost, potentially a gasket pre-cat converter.
So its a strange one and could possibly be turbulence or something. Happens only between -50 to -40 vacuum
If I am going up a hill it's pretty easy to stay at the exact point and it just whistles as the same tone no matter the rev range.
So bizarre hearing him talk normally cos he's a pommy!
Clay is a strange looking man :yucky::laugh:
Still there :(
Lame!
Car feel any better?
Combo of the 2 Duncan. ;)
I haven't seen this Game of Thrones but I have heard it's pretty full on...
Would you guys say it is inappropriate for a 15 year old Girl to watch?
I only ask as my Niece watches it with her Father and from what I've heard, I don't think I would allow it.
    • I agree that delayed payment probably isn't the most suitable solution. It seems a solid complete transaction would be best. As I wouldn't be using this sale as a line of credit that would typically earn interest, we can probably arrange a much cleaner single transaction deal. I can do $92.52 today. Would you prefer EFT, or Cash on Pickup?  😛
    • Oh man what a deal.... Funny enough (well not really) I sold a car to some old dude (buying for his Daughter) on a Saturday, He asked if she could take the car now and pay me the money on Monday as the bank wasn't open. Needless to say I told them to come back with the cash or get f**ked! Luckily the money seemed to magically appear in his pocket a few minutes later, so it all ended well (for me).
    • Gucci bags tend to hold their value well, so someone’s definitely going to get a nice find here.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
