Found some vids on youtube of a jap guy rebuilding the Nissan R200 diff.
He even does the centre and checks backlash, all easy to see the exact process.
So im thinking of giving it a try, all i need is one of those dial guages, seals and bearings, and the right shims.
Its NOT the diff shimming process that is explained in the diy section.
Its a full reco.
Jezza, you must watch the movie this is from:
Its called Full Metal Jacket
Haha I've been looking for this movie to watch - haven't been able to find it. Hopefully Netflix has it, however- GTA V will be taking up my time this evening :D !
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
