Yea that hill is called the dipper, they sit down the bottom and occasionally up the top, but far more often the bottom
I drive a truck, I have to be careful with that hill when I'm heading North, its easy to roll some speed up ;)
Edited by gtr judd
it wasnt an R8
haha only never to get caught too. Its pretty damn tempting with a big stretch like that.
Nice im sure they have some tweaks atleast ECU or they have some serious skill. quick enough to catch some hektik boys in a Ferrari. But again I guess theyre seriously trained.
I'm actually really surprised they'd bother sitting up the top...I mean it's not often someone would manage to pull a decent speed UP that hill worthy of the cop's time sitting there.
Because they so frequently sit down the bottom people will look and see nothing then nail it, its still easy to sit on 130 + up it
Also the get people going North from the top too. Same With down the bottom
I read that they:
after a bit of googling the VE's are the same just have heavier duty suspension, brakes, alternators, batteries. engine wise you still have the same gutless 3.0lt v6, (or 3.6 depends how old they are)
If you have cruise on, you do exactly the same up as down :P I bump my cruise back cos I know they're always there... it's funny seeing people go around you and then hit the anchors as soon as they spot the police car lol.
I read that they:
HWP are usually SS or XR6 Turbo, so not quite as slow as a bog stock commodore. Have seen cops at the bottom of that hill in the past.
I was even driving a Nissan Patrol down there one day, and sitting on 110 exactly - the cop, hiding in the bushes at the bottom of the hill, gave me a dirty look, even though I'd done nothing wrong. Seems easier for NSW Police/Govt to just punish you when you've done wrong, rather than being visible and preventing accidents in the first place (by, say, oh I dunno... mandating defensive driver training)..
^^^^ I second the dead stock comment. They are stock ss, xr6t, xr8.
Sydney have sweet cop cars. Unmarked typhoons and shit.
Does this stretch of road have bridges? And a wind sock up the top?
I drive to and from Sydney every day, I know there hidey holes :)
f**k you're keener than me, once a week is bad enough.
no point worrying about the cops....just set cruise to 113 and enjoy the scenery
f**k you're keener than me, once a week is bad enough.no point worrying about the cops....just set cruise to 113 and enjoy the scenery
I have been doing Canberra Sydney Canberra 5 days a week for the past 5 years lol, 3 years prior to that it was 3days a week lol.
I know that road very well ;)
My truck is limited to 101, but I can roll up to 130 easily :/
A cop used to live down the road from me a few years ago. He brought a XR6 Turbo and I had a quick look over it. Pretty much appeared standard except it was chipped by Unichip. It did seem the springs looked a little different but it could have been from the extra weight of the car (if any).
A mate of a mate, years ago bought an Ex Police Clubsport from Auction.
It was definately Not Stock.
I thought I heard somewhere that they Chip them, Maybe Head work and raise the Compression?
Also better handling mods.
Cruise in the Soarer ony lets me do 108 :/
funny you should mention. the cima stops at 109 too....f**king annoying, I was seriously considering getting higher tyres.
the stagea cruise on the other hand seems to be happy to go to a million
anyway....what's all the love for modified commodores around here....no matter how much work they've done it won't count for more than 10% extra on stuff all which is still stuff all :) And my bet is there is nothing mechanical changed in the motors
    • 49719 is the cooler loop. Right at the front, LHS of that diagram. Return line from rack (LP side) goes to cooler loop on RHS front of car, then back under engine and returns to bottom of tank. 49717M is feed from tank to pump. HP line out of pump is thick rubber, followed by the hard line that runs down to crossmember and runs in parallel (but opposite flow direction) to the LP return line. Nothing goes anywhere near the firewall or interior of car. The closest they get to that is the connections on the rack.
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
    • Don't worry about. Just don't try to drive hard enough to make boost and you'll be fine.
    • Yes. This has already been said. It is a loop of hardline in front of the radiator. Because.... the pump is on the LHS and the steering rack hydraulic connections are where they always are on a RHD steering rack....on the RHS. The high pressure line goes down under the engine, along the crossmember, like it does on all Skylines. Don't just throw expensive braided hoses/other kits at it. Work out what is wrong and fix that.
    • Still got the afm on the intake, clamps are shut tight, only loose hose is the one that goes from the j pipe towards the IACV, since it's next to impossible to find a factory hose and the barbs are different sizes (I'm still using clamps on this hose to try and help it seal on the iacv side) I've ordered parts to make up the hotside of the intercooler pipes, I'll plumb it in and see what happens in a few days I suppose The turbo's internally gated, can I just unscrew the tension rod to let the gate open?
