Yeah the GTR is pretty crazy. Auto suspension adjusting. It also has RWD function (AWD only initiates when traction is lost this is in the 2012^ models I believe - I tried researching into this - not much is said. I notice in pre 2012 models that salesmen and reviewers were calling it an AWD but from 2012+ they started explaining the function of it's RWD/AWD a lot more indepth and openly). The balance of the car is perfect to say the least. Everything on that car was designed for a purpose.
The graphic work is to hide the aero designs before the release - I'm sure it serves multiple purposes such as 3D design work but it's mainly to hide the "look" of the car until it's released. Which is why there was a huge following when the R35 N1 was leaked a day before the Tokyo motor show - it didn't have the paint work so all lines were able to be seen.
Edited by RosieR34
Unreliable gadgetry. post-89755-0-07734200-1384915227_thumb.jpg A top fueller goes 0-400 in 4 seconds, on a sht run, no traction control.
After watching that episode of Top Gear with the 959 and the F40..... that explains it perfectly; im an F40 guy, just the bare essentials, the driver is traction control and abs. Pure driving.
I wish that there were more cars that followed the F40 philosophy.
Unreliable gadgetry. attachicon.gifold.jpg A top fueller goes 0-400 in 4 seconds, on a sht run, no traction control.
Agree entirely.
A top fueler needs a rebuild every meet, weighs half as much, has tyre 4x the size and isnt offered with a warranty
  • Like 1
Does anyone happen to know how hard it is to get a windscreen for an R34?
Mine has a crack and i think i might get it fixed before it goes in... can i reuse the original trim or can you get those as well?
shouldnt be too hard.
I believe most of the companies can get an aftermarket one.
and they should replace the seal also.
Yeah sweet, i assumed glass would be easy enough to find. I was more worried about the trim and a possible 10 week wait or something.
Might give them a call today.
Thanks fellahs.
    • The water pump is know to leak as well. So if the coolant is low checking that first as well as hoses.
    • Reading your posts Josh, sometimes I feel like I've gone in a time machine back to the 90's when everyone was doe-eyed and figuring things out for the first time.  I've lost track of how many single turbo GTR's I've seen on track that haven't burnt down lol. Everything has been figured out a long time ago. These things are at the point now where its essentially turn-key to go single turbo.
    • Among other things yes. Making sure to either use an oil pressure regulator or the right restrictor size for your oil pump/range of oil viscosities you intend to run, making sure you plumb the lines correctly, turbo should be placed such that it siphons properly even when the water pump isn't turning so you don't boil coolant in the turbo after shutdown, oil return should be low resistance and also preferably picking the one that is most likely to return to the pickup as opposed to some other irrelevant part of the pan. It's far from impossible to figure this out but I have seen people really, really struggle and if that's the case it's easier to just take the path of least resistance. To me, bolt-on twin turbos are a fixed cost whereas single turbo is almost unbounded.
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
