Can you disconnect an electric oven without needing an electrician? What's actually attached to the power?
turn all power off.
every single circuit breaker.
pull oven out.
unscrew all plates over wires.
unscrew wires.
dont turn power back in until new over is in.
Hahaha Very Coot!
The dog aint bad either. :D
Charlie is a Cavocker. (King Charles Cavalier X Cocker Spaniel) but amongst other things, he's a Scooby Dooby. aka Scoob. :P
This time 2 years ago his name was "Major".
so, mash fan?
After Wakefield this morning, i thought about what im doing wrong.
And this scene came to mind. (from one of the best films ever, in my opinion)
http://www.youtube.com/watch?v=3T-VAi2Xqq8
My methods are unsound, if i have any method at all.
  • Like 1
Boiled the brake fluid, thats not so bad, low oil, could keep going with top ups.
And my diff started leaking badly from the front seal. Better stop before i wreck it. i just spent $2000 on it.
So ill get the diff fixed, and before i go again ill put new good brake fluid, and take plenty of spare oil.
The basics is what i failed on, oil and brake fluid, i feel stupid.
The diff is just bad luck.
Any idea where the oil went?
Catch can? Head? Water? Etc...
I saw no smoke.
that whole no oil thing is a mystery. it sounds like there wasn't any leaks?
bad oil ? engine running hot?
I counted 8 cops on foot out the front of the formal we did. Not including the 2 MC cops and the pursuit under the bridge that pulled MiK over.
Crikeys - generally if we do formal runs we take awesome care of our cars. Go hit the Kambah Commonwhores FFS !
  • Like 2
I can understand cops being there for general crowd control, and if some douche decides to drive dangerously with all those people around.... but RTA inspectors is just a c#nt act in my opinion.
i'm not certain you can defect a defected vehicle.
I'm also not certain if an additional penalty applies if your already defected.
would seem superfluous wouldn't it
Edit: Can you/should you even drive a defected vehicle on the road ?
Edited by Sinista32
Usually a defect notice gives the owner a time frame to repair the defect and have it inspected .... if it's not put 'off the road' then it really cant be defected for the same thing.
But I really have to agree with Shell ... cops fine, but the other is fishing with hand grenades.
Edited by THE34T
  • Like 1
    • @joshuaho96 Hmm considering the drama you've seen/experienced, have you looked into getting a built complete long motor shipped from Australia?  Considering the AUD is basically monopoly money when compared to the USD, at a glance this seems like a good option?
    • Bloody Skylines, they put you through the bloody wringer! Stick at it! Stunning drag strip BTW! Where is it? Can see part of the name on the slip and probably should just Google it!
    • I mean the other day I had to walk someone through diagnosing why their timing belt was walking off the cam gears. At least one of the issues was a bent tensioner stud. Local mechanics have found runout on the CAS mechanism causing weird failures. I'm also no saint here I've documented some of the things I've had to learn the hard way. Something I discovered recently is that my CA emissions catalytic converters weren't even welded correctly to align the downpipe to the main cat and they tossed the support bracket that goes from the transfer case to the downpipe to support everything there. I spend a lot of time chasing down these decidedly unsexy problems and the net effect is it feels like I never actually get to the original objective (flex fuel, VCAM, oil control, cooling, etc).
    • At times with how you make everything sound, all I imagine Americans doing when they see a gtr is standing there looking at it and bashing it with a gun like how a caveman would with a club and hoping it fixes itself
    • I think this is just a product of how the US market works for this stuff. Shops are expensive and there's no real way of knowing what kind of results you're going to get, people don't really have the institutional knowledge. I have heard too much at this point to really put faith in anybody "full service" except maybe DSport and they aren't really a full service kind of shop. If you go to the right place I have no doubt they'll get it right for you. Some locals have set it up right but the cost really is nuts and even now they're still fighting issues. And you know I'm a crazy person who thinks things like twin scroll, relatively short low-mount cast headers, PCV recirc to intake, recirculating BOV, right-sized for ~400 whp, MAF load, validating all of that to a standard comparable to OEM test programs, etc are relevant. For what it's worth, multiple local owners at this point have been stuck in a perpetual cycle of blowing a motor -> getting someone to rebuild it -> some missed detail causes the bearings to wipe and spin just outside of break-in mileage or drop valves or some other catastrophe -> cycle repeats. I usually only find out about this because I'm perpetually helping random friends with diagnosing car troubles, Skyline or otherwise. The single turbo stuff if I'm honest is mostly secondary, it just doesn't seem to achieve the numbers in the ~2000-3000 rpm region that I would expect given the results I've seen here or in Motive's videos. I don't really know what we're missing here in the US to be causing this. Lots of people like to emphasize the necessity of finishing the project first and foremost, but I'm not made of money and I can't afford to be trashing a 15k+ USD engine build with any regularity. Or spending my relatively limited garage time these days unable to triangulate problems because too much was changed all at once. Also, even if it isn't a catastrophic failure I would consider spending the cost of single turbo conversion with nothing to show for it to be pretty bad.
