Im thinking then the only annoying bit would be if its got coolant lines, then you have to drain the coolant.
Oh and some of those bolts holding it together would be tricky to access.
I have ratchet spanners and stuff to get to annoying bolts if you need.
i found a good trick is polish it real good, spray with good clear bonding agent paint, then gloss clear over that.
Polished forever.
Blacken that lip. :mrt:
Thinking of lippage for the Wagon too, maybe a Foamy one like Chris's or perhaps something else.
Tried one of the Kebabs from Charnie just now. Jeremy, I now know why you get them. MMMmmm mmmmm... :P
yea, they shop up the road sells them! I can barely finish one :/ they are huge
Foam lip? that sounds like a good idea.
Light, soft and able to resist lots of air pressure.
Mint snowfoam lance turned up today, watching the weather so i can do a wash and try it out. Might have a go at polishing and everything.
Also found that Masters hardware Workzone brand pressure washers are the same fitting as Bosch.
The doofus at the hardware counter said " The Bosch rep said not to use other brand products with the pressure washer, we dont have any parts, we just got them for christmas."
The hose fits perfectly, its exactly the same fitting. Thanks to ignoring the idiot staff i got the right hose.
So now i have 11m pressure hose and good accessories.
:santa:
Yarralumla kebabs FTW. By far the best ones I have ever had
Charnwood The land of goat sphincter rings kebabs are pretty insane. It's probably the only thing Charnwood could "claim'. :(
Yah! as stated, the Kebabs are Very Good. Big, Filling and well worth the price. Might try their Pides too.
Charnie also has : A Very Good Dentist, The Takeaway does Very Nice Pizzas, Burgers, Steak Sambos, Scallops etc... makin' me hungry.
The Chinese is also Tops.
and the Woolies chick that Loves Skylines. :D
  • Like 1
    • @joshuaho96 Hmm considering the drama you've seen/experienced, have you looked into getting a built complete long motor shipped from Australia?  Considering the AUD is basically monopoly money when compared to the USD, at a glance this seems like a good option?
    • Bloody Skylines, they put you through the bloody wringer! Stick at it! Stunning drag strip BTW! Where is it? Can see part of the name on the slip and probably should just Google it!
    • I mean the other day I had to walk someone through diagnosing why their timing belt was walking off the cam gears. At least one of the issues was a bent tensioner stud. Local mechanics have found runout on the CAS mechanism causing weird failures. I'm also no saint here I've documented some of the things I've had to learn the hard way. Something I discovered recently is that my CA emissions catalytic converters weren't even welded correctly to align the downpipe to the main cat and they tossed the support bracket that goes from the transfer case to the downpipe to support everything there. I spend a lot of time chasing down these decidedly unsexy problems and the net effect is it feels like I never actually get to the original objective (flex fuel, VCAM, oil control, cooling, etc).
    • At times with how you make everything sound, all I imagine Americans doing when they see a gtr is standing there looking at it and bashing it with a gun like how a caveman would with a club and hoping it fixes itself
    • I think this is just a product of how the US market works for this stuff. Shops are expensive and there's no real way of knowing what kind of results you're going to get, people don't really have the institutional knowledge. I have heard too much at this point to really put faith in anybody "full service" except maybe DSport and they aren't really a full service kind of shop. If you go to the right place I have no doubt they'll get it right for you. Some locals have set it up right but the cost really is nuts and even now they're still fighting issues. And you know I'm a crazy person who thinks things like twin scroll, relatively short low-mount cast headers, PCV recirc to intake, recirculating BOV, right-sized for ~400 whp, MAF load, validating all of that to a standard comparable to OEM test programs, etc are relevant. For what it's worth, multiple local owners at this point have been stuck in a perpetual cycle of blowing a motor -> getting someone to rebuild it -> some missed detail causes the bearings to wipe and spin just outside of break-in mileage or drop valves or some other catastrophe -> cycle repeats. I usually only find out about this because I'm perpetually helping random friends with diagnosing car troubles, Skyline or otherwise. The single turbo stuff if I'm honest is mostly secondary, it just doesn't seem to achieve the numbers in the ~2000-3000 rpm region that I would expect given the results I've seen here or in Motive's videos. I don't really know what we're missing here in the US to be causing this. Lots of people like to emphasize the necessity of finishing the project first and foremost, but I'm not made of money and I can't afford to be trashing a 15k+ USD engine build with any regularity. Or spending my relatively limited garage time these days unable to triangulate problems because too much was changed all at once. Also, even if it isn't a catastrophic failure I would consider spending the cost of single turbo conversion with nothing to show for it to be pretty bad.
