Does any body on SAU work at Trojan, thinking bout takin my car there to fix the defect stuff but wanna chat first. Or is there someone who's best too talk too? Do they give us any sorta deal?
Thanks guys. I'm still thinking I may do it myself buuuut then it maybe better to just get it done.
As for replacing upper inner control arm bushes and radius rod bushes, what's best to go with? OEM, nolathane?
Well, totally different but same, the SkyWagStag now has 4 lots of either New or good second hand Nolathane bushes (Castor, Swaybar and Swaybar links) on it.
Being much better condish than the 24 year old Flogged out ones, they make a huge difference. But I guess new OEM ones may well be the same.
I just got whatever was cheaper.
Rubber is better, even for racecars.
It takes up the shock and vibration without getting loose.
Also John at Trojan sold me those volks for $600. Was $800 but he couldnt get a part or something so i got a discount. He is very nice.
$800 was a bargain anyway.
Well thank jeebus the hot weather is over.
I can move again, and be outside during the day.
Whiteline do rubber too.
Hardrace have the option of hardened rubber, but its mostly arms n stuff with the bush already in it.
Also stay away from rose joints or pillow ball joints, they suck balls, and wear very quickly. Bastards need replacing in 6 months.
Yes i wasted money on that crap. Thanks Driftworks, wankers.
there was sudden rain down at my dads in Calwell for about 10 mins yesterday, got out of the pool, smoke everywhere, herd thunder and the raid instantly came down hard! the heat cracked a pipe for the pool heater so lost some water out of the pool, the rain filled it again within 10 mins....
so I went inside, jumped on gt6, got the 33 and went drifting :)
Edited by ..::R33GTS-T::..
I just hope they will at least re-look at the highway driving. Making it 120km/h would be a great increase. That way I can drive 130km/h on the highway instead of currently driving 120km/h :D
    • Looking at finally painting and installing my R32 GTR wing I bought back in 2018. I got two quotes: Quote 1: $880 includes: wing, spare boot, holes welded up prep/paint. Pro: full boot with wing AND hole-less boot with lip i can swap between Con: $$  Quote 2: $330 wing only. Pro: cheaper Con: lose my (relatively) rare no holes sedan boot Also to consider I do plan on painting my whole car at some point "soon" (been saying that since 2018) Anyway Enjoy these All Japan Day 2025 pictures of my 4 door, still rocking the Calsonic Livery! Rolling in Interior shot Matching Peer Pressure Racing overalls are pretty cute ngl. This year was a hard 1990 cut so I got to be over with all the older cool stuff Next to arguably the best car there. A mighty S-Cargo
    • I personally would run 2x from the cam covers into the catch can, 1x sump vent to catch can (would mount this at a low point of the catch can, so it can also act as a drain). I would see if you can run a -12AN down there to improve venting and also draining. The head drain thing, just drain that back to the sump on the other side. Catch can to be vented, unless you plumb or back to the intake.
    • Yeah the head "drain" is rather a sump/crank case vent. My catch can stopped filling up after venting the sump to the catch can. I have 4x fittings in mine, which is about 5Ls. 2x cam, 1x sump vent/catch can drain, 1x fitting back to the intake and a massive breather which can be blocked so it's a fully sealed system.
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
