phone LCD screen replacements
anyone know who/where does this and can be trusted ?
I have 2 HTC Mobile phones where I have cracked the screen
These are worth $450 and $650 bucks so I'd like to see if I can repair them
all help appreciated :)
I've done it before on HTC depends which model it is I can probably do it for you. Sometimes you have to get the LCD plus the digitizer because it's nearly impossible to seperate them.
You can try the phone shop vendors in tuggers mall or Woden infront of Vodafone
Soda blasting was used on my GTR bonnet. Very gently but still managed to rip a whole in the alloy bonnet.
I think in the hands of an experienced operator it has it's benefits.
I expect rubber and sills need to be covered correctly or avoided.
Ive always done my cars prep by hand. The whole lot. Takes a long time but you get better results. Hope damage was not too bad Mik.
The rubbers can be fixed, they are old and hard and can be sanded back, maybe thats why the soda did that.
The plastic bit in the back window seal is fked anyway, i might cut it out and do a bead of sealant in the gap.
So in hindsight, you can sand just as close or closer than you can blast, and blasting lifts the rubber and leaves crud under there.
Im glad i only did a couple of spots, ill have to clean behind the rubber to get it sitting flush again.
Its good for getting paint out of the tight corners, and probly good for cleaning small metal parts
Its not working properly, the guy sent a bag of the wrong soda, so it clogs up. It works with constant shaking, but thats kinda hard to do while your trying to use it.
I cant get blasting soda in canberra that i know of, and the car will be primed before the right stuff turns up....... :/
Maybe ill do the old wheels or something.
Caught up with a few mates and went for a quick cruise - they met up with the Braddon guys... left there not wanting to be around kidz doing fatty skiddiez. So went up to Mt Ansilie and chatted about Initial D with a m8 who tagged along then went home. So good taking Rosie out for a long nip :)
Spotted a R33 GTR and a white R34 GTT and about 50 SS's haha
Edited by RosieR34
    • Ah yep. I asked a auto electrician about getting a cheap rebuilt alternator vs a new one. He also said he used to it back in the day but it ended up costing similar to what a new one would and recommended getting a new one,.
    • Ah, to clarify if the car has already been tuned and has been modified and you want to go from a oem cat to a 100 cell or decat or vice versa.Are you saying that the car doesn't need to be tuned after a cat change if it's already been tuned?
    • This has been covered a bazillion times but google wet boiling point vs dry. Motul is only good when it's fresh, once it absorbs moisture it gets pretty average very quickly. So as above, make sure you change it if you're going racing. I run the Endless brake fluid in mind, but only because a mate is a distributor and it's cheap. It's not quite as good as SRF but I'm running 380mm rotors on a Skyline so it's not like they get hot.
    • That's the thing, they still add it and it makes fuel cheaper, implying adding 10% of it drops the cost of 91 by what, 5c a liter? I remember when it was barely half the price of 98. Because you know, 85% of what is in the fuel is way cheaper than 91 fuel is by volume.
    • Auto electricians that do repairs on automotive AC systems can source service kits. I don't know where they actually source them. I do know that there is one available for the R34 comp that I would need it for. If you have to pay someone to dismantle, clean and do needed repairs and fit kit contents, then you'd probably end up spending a good fraction of the cost of a new one. I would not be paying for that, because I would be doing it myself. My mechanic (bro-in-law) will happily source what is needed. Back in the day (like in the 80s and 90s), rebuilding an AC compressor was the standard approach, same as for starter motors, alternators, etc, because new replacements were v. expensive. After the China manufacturing boom and the rise of the disposable approach to everything, people just started throwing broken/worn stuff away and not rebuilding things.
