Yeah the one here isn't armed 100% of the time. But it's held here with everything it needs just incase of an emergancy, Like if a high profile flight is coming in they deploy it as a care package for said flight (and they can't get one from Williamtown). I hear that they want to have a landing strip @ JOC intime for the F35 Lightning Launch, as the F/A-18 is due to be decommisioned soon.
Edit: the one here i believe they rotate from Williamtown i don't know if it is the same plane all the time. But i see 1 at least 1 time a week.
Edited by Anfanee
Hmm one of the Varients of the F-35 can takeoff vertically and land vertically. So they may not even put in a runway.
Australia is not getting the vertical lift JSF's they're only for the marines from memory and I think UK is having a few. We've already have a handful of them, but they're currently in the states being tested/worked on but they are AU JSF's - be quite a few more years before we start seeing them around Australia.
Yeah i know full deployment is for 2020. Prob more like 2025. Guess we will find out.
My point was there should be a jet in Canberra ready always coz 15mins is a lot of time. Theres a parliament house. Good target.
15mins from Williamtown to Canberra - it would be a lot of time if the enemy was flying in Canberra, but as I explained in a previous post - enemy jets wouldn't get to Canberra in time for that. Too much radar etc. It's not like the US/EU where you can look across the field and be looking into a different country.
F 35 is a dual purpose bike plane.
:down:
F 22 has gone down the same path as the Comanche
Theres only so much g force a body can take, and heaps of older fighters are that good.
Unmanned is the new thing.
:down:
So wish the Comanche went into full production :(
    • careful when running the car after a boil over. Ive heard you can lose enough coolant that it won't show the right temps because of too much air in the system (or something like that). Make sure the levels are good before trying again.  Maybe a mobile mechanic can come have a look with their scan tool ?
    • OK, just for some extra clarity - there is more than one option at Frenchy's. 1. You can buy the whole kit - with or without the actual compressor. The whole kit includes mounts, hoses, condensor, etc. That's either ~$2200 or ~$2800. No surgery required with this option. 2. You can buy just the bracket (~$600), or the bracket with the compressor (~$1200). Either of this or the above option "without the compressor" is if you already have an Echo comp or you are able to source one locally. Whatever the case, in this option, you will need surgery done on your hoses to adapt to the new compressor. When I said "the Frenchy's kit", I meant the whole kit in option 1. It is obviously somewhat more $$ than a $1500 OEM compressor. But if I had to spend $1500 on an OEM compressor, I would certainly consider spending double that to renew and significantly update everything forward of the firewall. Another option is to rebuild your original compressor. My R34 comp is currently dead and I will be most likely doing that to it if the spare one in the shed is also leaky.
    • I’m thinking that’s the route I’ll  go, thanks for the input!
    • Hey all, my 2004 Nissan Skyline 350GT overheated the other day with coolant boiling and leaking out of the coolant reservoir when I was parking. So today, I started it up again just to see if it was a thermostat/head gasket issue. After about 20 mins of running, temps were normal again, no coolant was leaking out and the upper reservoir hose was warm but my engine suddenly cut off. I checked the oil dipstick and cap when it was running and there was no white foamy residue and the exhaust did not have white smoke. I tried starting up the car again but it would only crank, similar to when I had a camshaft sensor issue just that now there’s no check engine light on the dash. Any ideas? Unfortunately I don’t have an OBD2 that can read the Nissan's programme.
    • Bump on this to not make another post, had a ‘head drain’ leak on me and have the engine out as we speak. Planning on just putting a new freeze plug back in , plug the tapped holes and just be done with that headache.    Now I still want to relieve pressure to allow oil to pass down the blocks returns easier. I’ve seen catch cans with multiple vents help folks with this issue on this forum.  I’m wanting to make my own. I have some pictures here of my setup if anyone can help how I should plumb and design the catch can I would deeply appreciate it !   rb25 Oil upgrades: 1.0mm restrictor n1 pump/billet gears extended crank collar  extended sump with trap doors/w welded fitting
