Cool. Any idea the best place to get one? Closed my door when I got home and the window exploded!
That is Crazy! Do you think it was touching something hard inside the door?
or maybe too much air pressure inside... Seals too good.
Trojan? or whatever JapSpec turned into?
or Try Jap Parts in Fyshwick maybe...
Damian 0449775209 -
Ph: 6280 0606
Ah: 6280 8898
Tell him Rob with the R31 Wagon sent ya! :thumbsup:
hmm that is strange....I agree it seems likely it either hit something inside or maybe the lower seal is rusted/loose?
anyway, if you find a window in Sydney I can bring it down next week.
Bub wanted to get up at 5 this morning.....
Lucky he did, i found water spreading across the lino floor.
One of the fishtanks is leaking. Emptied it out, fish in a bucket, took it outside.
Good excuse to get rid of it...... dont tell the missus i said that. ;)
less fish time=more skyline time
Anyone want a pair of Angelfish?
Edited by D.I.Y. Mik
I once had an old Pintara as a daily that someone smashed the window on. We got the window from the wreckers and I can't remember it taking Pete more than a couple of hours all up to fix?
Different car but still Nissan with all electric bits etc.
Surprised also if there's not a tutorial on here how to do it somewhere.
Hi Eric - have done it twice on my 32
It's not complex at all but the first time will take 1-2hrs. It's mainly about the angle of getting glass out/in.
Make certain you give it a great vacuum if the glass has shattered.
It gets every where but particularly on the brushes and inner/outer window strips
Which means if you don't do it properly your new (2nd hand) window will scratch-up the first time you put it up/down.
It's 10 minst to get the door card off and all the window switches out and unplugged
bout 10-20 to undo the nuts holding the window in
bout 10-20mins removing the window - but if yours is shattered just the thourough vacuum and removal of broken glass.
I did it alone but it would be a lot easier if there are 2 of you. Just balancing the window, slotting it in and doing the nuts up whilst the other holds the galss in place.
TFE mate.
$150 for a window and $300 to install it.
How hard are they to install? Anyone have any idea?
Cheers.
It wont be too hard would just need 2 sets of hands to do it.
I might be able to assist tomorrow night if you need
yeah DIY is very do-able, cleaning it out is the pain as said above. Also check for rust in the channel that holds the window, and also rust or damage to the "waist mould" that goes along the top of the door.
the only other issue can be adjusting the window afterwards (we had heaps of trouble in the 350z) but I think a 33 should be old enough to just do a straight replacement without any annoying adjustments.
    • No......not yet Minister for War and Finances has stated that the Commodore has to go first Not that I am going to modify the NC any more than what it is already modified now.....
    • Thanks again, really helpful chap from alpha omega wanted to speak to me, little concerned if this is meant to he aero alloy/ airospace quality and car sitting on drive has caused this.  Airplane are subject to much more changing temp and conditions than road salts! My caliper, many other components much older have surface rust but never eating part of the metal   Had I not seen it , could have been a disaster! specifically on rear part of bracket coming off like biscuit will update on what they say, helpful people so far
    • January or Feb is it booked in for turbo fitment?
    • The MX5 has had some annoying rattles in both front doors over bumps So I installed fancy pants door bushings, which stopped all of the rattles with the windows up, but........with the windows down there was still rattles, so after some googling,  and a chat with MX5 Mania, I got some new door to glass weather seals, all the rattles, windows up, or down, are gone now Shout out to MX5 Mania, the weather seals were on sale, and when I head to Dural to pick the up they even fitted them for me for free I did see a "really" nice Blue NA sitting out front   and this Black NC PRHT that looked like it has sat in the sun for its whole life and never had a wash, the clear coat was non-existent, an it looked horrible, really horrible, but, it had a nice turbo kit with over 200kw, the thing went like a cut snake, bagging the rears through the gears and dosing like a champ 😍 But, as I've always stated, I am keeping my NC na, I'm happy with the current power the car makes In other news: MX5 Mania do a drive in drive out turbo kit, the only minor additional part recommended for boosting my car, as it sits now, is a oil cooler, and that bonnet vents are definitely required for track use Aftermarket version look a bit to "racecar" spec I wonder how Focus RS bonnet vents would look?????
    • Paint is only structural when applied to the outside of Chinese and Indian cars. Otherwise it should never be present between mechanical joints that were intended to be metal to metal. Pain slips, slides, cracks, compresses, and add thickness that wasn't intended to be there. It comes firmly under the category of "just no".
