I dont know a lot about it but from what I knows I'm not interested in it.
Too few pumps, big dollars to set up, less millage.
I like the idea of cruises and I feel it will limit that and cost more.
But like I said I Dom know a lot about it, might try find a doco
E85 is for the weekend warriors! Premium is for us daily drivers :P
Even though mine isn't a daily, 98 is for me, also my boss pays for it :)
Full flex tune :)
E85 on the weekend and 98 mid week
I have seen these flex tunes, does it run 100℅ on either, or is it like the old gas tunes where it runs better on one? Does the tank need to be nearly empty to swap between them?
Nothing wrong with using E85 Daily. Unless you are running turbos larger than -5's Judd it isn't worth the upgrade though.
I will never run bigger then -5s even -7s would make me chub up enough. I have a mate with an SS on OEM e85, too little servos, it just seems inconvenient to me....unless its a dyno queen. But that's a whole different gear grinding story lol Edited by gtr judd
Full flex means you can run any mixture and it's the best way to go. Price for the tune works out to be double a normal tune so around $1500 but then all you need is a capable ECU and a fuel sensor.
It will of course run quicker on e85 but when running straight 98 it will run just as good as a normal 98 tune because it has the fuel sensor and adjusts the map to suit
  • Like 1
Is a loverly looking Beast. ;)
I Finally got me a decent Camera today thanks to Ebay.
Gone from a 4mp Sony point n shoot to a 12mp Pentax DSLR. 300mm Zoom is also in the Post.
Yay. :bunny: about time.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
    • To be fair - you see the same thing for every clutch. There's always someone making an installation error.
    • Just saw this, redacted names. It's on a R33 GTS-t Facebook group. Looks like still teething issues.
