Rebuilt my PC. Pulled it apart, cleaned everything and put it back together. Also put a new CPU cooler in and Overclocked the FK out of it. Result: what feels like a brand new PC! (It's 4 years old)
When I get back can you help me OC my pc
got myself an i7 3770k
Yeah no worries Dan. It's pretty simple. Did you get a decent cooler for it?
That will have to be the first thing I do when I get back. Right now it's just running a stock cooler.
My GPU is a HD7950 I believe, might even purchase another one depending on how much money I save while over here.
An SSD is probably on the cards as well.
This is currently the best value cooler on the market and is ranked 3rd for air coolers. It is the only one worth buying unless you want to water cool your PC. If you have not got an ssd I do highly suggest one. Is the 7950 a 3gb card? If so that is still overkill. I run bf4 on ulta with my old gtx570.
http://www.pccasegear.com/index.php?main_page=product_info&products_id=18670&cPath=23
Happy belated Bithday Shell!
I never knew why shell reduces the content blend in winter. It s because its so hard to start the car when you're at 85%. So when to the servo bought a gallon of 98 o dilute the E85. It started on the first go this morning with ice all over
I'm sure some of you guys have heard of Nigel Petrie and or seen his drift Hilux. Very well put together doco showing his passion and his commitment to what he loves. Great stuff!
http://vimeo.com/93566294
Wow! Awesome Watch.
If that doesn't inspire anyone to turn a spanner then nothing will.
(got the day off today) :D
Gonna turn me a spanner.
I'm sure many of us would love to achieve that moment where no screw or bolt is to much for the mechanical mind ! What he has is a chronic passion - beautiful thing to see.
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
