In all fairness, the servos just distribute the fuel they are supplied with, so sometimes it may not be their fault. I have some very interesting "diesel" samples at work, a few of which turn into the jelly when really cold!!!
Little bit annoyed.. Meant to take Rosie in for her SAFCII tune tomorrow, but I "busted" my knee at my first Gridiron game and can't drive it there -_-
Oh my... Not good Jeremy. :O
Bugger mate, you didn't kneed that (did I just say 'kneed'!!)
Do you live far from where you are getting the work done? perhaps under the circumstances they might send someone to pick up Rosie, after all, it's not like you will kneed the car back real soon. Is it worth a try?
  • Like 1
Shit dude. sorry to hear.
much pain?
Wasn't done at the Spears game was it?
Yeah, lots of pain :( Dr said 1 week, I am finding it hard to see this amount of pain go away after a week but... we'll see. We were versing Firebirds, the spears were before us.
you really funny m8 you kneed to chill m8
Usually find the "crap" batches are either full of white spirit or ethanol.
Or in my case today dirt and water
Leaky tank.
They had a problem at our local BP with the premium tank leaking, probably because they dug a huge hole next door and built apartments.
They cant dig it up for a while yet, so no premium is available at Jamison BP
When theres dirt and water in the fuel, its not worth going back unless they dig it up and fix it.
Jeremy: i have no acl in my right knee since i was 16. Trying to do motocross on a bmx.
There are many things i cannot do (footy etc) because of it, take care of it man.
Edited by D.I.Y. Mik
  • Like 1
    • Oh yeah forgot to also mention need to also unplug the IACV as well. Thanks for the reminder @MBS206 Unplugging the TPS takes it out of closed loop so you're able to screw down the IACV without the ECU trying to add/subtract timing to maintain the idle (not sure PowerFC can even do this, but Nistune and the OEM definitely does)
    • For sale is my 1999 Nissan Skyline R34 GT-T, tuned to 234 kW / 313 hp. I've had the car for a few years as my daily driver. The car is original (as far as Skylines go), with only a few minor upgrades to enhance performance and driving experience, as typical for such a car of its age. Overall, it is in great condition with no body rust, thanks to its earlier import date. It features a top-notch security system (not literally, but it's great!) with remote start and still functional 4-wheel steering via HICAS. It comes with several performance and handling upgrades, including:     Hypergear 450HP Turbocharger running 17 PSI boost, installed mid-2021 by Jaustech     550cc injectors     Nistune ECU     Front-Mount Return-Flow Intercooler     X-Force Stainless Steel Exhaust     Upgraded engine mounts     Bottom end bearings replaced     BC Coilovers     Lenso DR1 rims     Bridgestone Potenza Adrenalin RE003 TL 245/40R18 97W tires, fitted early 2023 The interior is mostly stock, with a few additions:     Viper Satellite Tracking System with remote start     Bluetooth Double-Din Touchscreen Head Unit     Steering wheel cover Cons:     A few paint imperfections here and there     Driver’s seat shows more wear than the others. It's not torn at all, but I've added a seat cover to protect its condition. I also have a CarVX Vehicle History report available for serious buyers, so you don’t need to purchase it yourself. Price: $26,000 ONO.
    • I've had two suzukis in the past have an extremely hard time turning over and not starting after sitting for a few weeks. Ended up the alternator would seize up causing the starter to force. Same issue both times.  Maybe they're sourcing their alternators from the same place...
    • Ah right. Maybe my rb just loves chewing through batteries lol.
    • On the R34 can't you just unplug the IACV? This is the way I've always done it on the R33. Disconnect IACV, get it idling around 650rpm, and then do a power reset on the ECU to get it to relearn idle (factory ECU).   The big reason no one has touched on as to why you'd want to get the base idle right, is that it means the computer needs to make smaller adjustments to get a good idle at 700-750rpm.   Also, cleaning the IACV won't normally make the car suddenly idle lower or higher. The main issue with the IACV gumming up is that the valve sticks. This means the inputs the ECU gives, aren't translating to changes in air flow. This can cause idle choppy ness as the ECU is now needing to give a lot of input to get movement, but then it moves too far, and then has to do the same in reverse, and it can mean the ECU can't catch stalls quickly either.
