i give info on (if anyones seen the adds or stuff on the news bout it) the new legislation about workplace and industrial relations reform policy and other things along those lines. started today and only had to work 5 hours but because it was advertised today i only got 3 calls! yay! but will be working 5 days a week in dickson :) the add is a long mofo and says "workchoices" numorous times.
congrats on getting a job, but let me get this right, people call you up asking about Howards IR reforms, and you tell them how good it is for them?
yeah pretty much i give them answers to there questions wether it works in there favour or not, but yeah thats what i do :) call it a hotline if you will (it was just called a line before a got there, then they decided to call it HOTline :blink:)
and i also send booklets about the shit to people who want one. basically call centre work :D so yes your right andrew thats also what i do :(
well i dont really undrstand it myself <_< but what i think it is, the government is changing federal and state awards (which means like how much you earn per hour and what the minimum is) and also unemployement benefits and long srvice leave and sh!t like that. i really dont know everything about it for me to make a deicision with wether i like it or not, i dont really care about it, doesnt bother me its just my job to tell people whats going on. ill need to learn more about it to take sides on with or against it.
and yeh hopefully when this contract finishes ill be transerred to another call centre in telstra :)
    • Hi all   what short shifter do you use on your skykine r34?   my synchronous does have a problem and i was getting huge delay and grinding sound between 2nd and 3rd, did put shockproof red heavy stuff and it is great now/ no issues   would in your view short shifter screw this up?   people seems to suggest/ use cube short shifter and there is standard and premium. Seen review of premium as much better and less play. Thoughts?
    • Yeah, there's a bit of a density and friability difference between pebbles and any of those other things. Silicone will definitely float in oil and so will be mobile enough to move around. Although, again, if it is upstream of the filter it really shouldn't go any further. I would only ever worry about silicone when it is in places downstream of the filter. Upstream of the pickup is a whole 'nother matter. We've all seen what that does. I have seen the most abominable crap settled out in industrial gearboxes, trunnion lube systems and the like, without any sign that any of it has touched anything in the machine. Just chilling in the bottom, waiting for the inevitable operator error that causes the whole machine to need to be dismantled for repairs.
    • I have seen enough fire and brimstone from TSBs about roloc disks causing spun bearings that foreign object contamination is top of mind for me. For sufficiently large particles you might be right but usually it’s a distribution of debris and some of the larger particles can also break down and shed bits. If local shops report RTV contamination in a turbo is enough to wreck them I’m taking zero chances if I can help it.
    • Ask and ye shall receive! (eventually... ☺️) https://www.goo-net.com/usedcar_shop/0170208/detail.html
    • Weird ! Same Same with mine. Autoexcel in Bonnyrig is your friend !
