38,000 kms odometer reading (motor built less than 2000km ago)
Induction & Cooling -
- Garrett custom 3037 {600HP rated) roller bearing (ICE / Race Pace customised)
- Greedy plenum (polished)
- Greedy triple core drag S15 radiator kit.
- Craig Davies 16inch thermo fan
• HKS Type R (108mm) Drag INTERCOOLER
- RACE PACE supplied top mount stainless tuned length manifold
- TURBOSMART wastegate
- Customised RACEPACE stainless piping throughout turbo/intercooler setup.
- K&N Air filter
• HKS HI’POWER 3inch CAT BACK EXHAUST SYSTEM
- Greedy 16 row oil cooler kit (anodised version)
Engine specifications - - fully blue-printed motor
Top end -head
• JUN SR20DET HEAD BOLTS
• JUN TITANIUM VALVE RETAINERS
• JUN 1.6MM METAL HEAD GASKET
• TOMEI CAM PULLEYS
• HKS LASH KILLER KIT
- Tomei pro-cams (280 lift)
- Tomei titanium valve springs
- Tomei solid lifters (non-hydrolic for sustaining high RPM)
• PORT / POLISHED HEAD & match ported.
Bottom end-
• JUN SUPER FORGED CONRODS
• JUN SUPER FORGED PISTONS
- JUN - PISTON RINGS
• JUN SR20DET BOTTOM END BOLTS
• ARC ENGINE OIL SUMP
Fuel System -
•NISMO 1000CC INJECTORS
- Bosch 044 external fuel pump
- XTR custom surge tank
• SARD FUEL REGULATOR
Drive Train / Suspension & Handling-
-Exceedy twin plate- brand new
- CUSCO 1.5 way LSD
- Project mU slotted & drilled discs
- BREMBO R33 V-SPEC calipers.
• CUSCO BRAKE CYLINDER BRACE
• CUSCO FRONT STRUT BRACE
• CUSCO REAR STRUT BRACE `
• JIC MAGIC FULLY ADJ COIL OVERS
• NISMO REAR ARM ASSEMBLY - upper & lower links
- C's short shift kit
ECU - electronics
- Micro tech LX series (laptop programmable)
- Bosch individual coil packs
Wheels -
• 18INCH VOLK RACING CHALLENGE RIMS - in rare diamond black (18 by 9 front & rear)
Exterior Cosmetics (lil bit a RYCE !)
• CWEST CARBON FIBRE BONNET (not on car but will provide)
• D-SPEED WIDE BODY FLARED/GILLED FRONT GUARDS
• CWEST Spec 2 FULL BODY KIT (sprayed in R34 GTR blue)
• NISMO CLEAR INDICATORS
• NISMO OIL CAP
• NISMO PETROL CAP
• NISMO RADIATOR CAP
****305 rwkw @ 20 pounds of boost**** Motor is built to hold 40 pounds plus. Only driven it twice since I got the car back from RACEPACE last weekend and I can tell you that the power is so usable. Starts producing boost at 2600rpm and its "fully on" at around 5500rpm. Engine is built for 9300rpm but rev-limiter has been set at 8000rpm. New turbo has got at least another 100kw@wheels left in it with a little more boost. With this power and boost level, it wouldnt even tickle this motor. Motor can easily support over 450kw @ the wheels (using a HKS T51R previously - it made 477.7rwkw earlier this year before MAS)
Well over $50,000 spent on parts and labour alone (not inc car). Car is in mint condition as far as interior and exterior. Engine has just been run in; less than 2000km on motor. Just spent in excess of $9000 on completely new turbo setup by Ben @ RACEPACE. I have receipts for all parts and labour since I bought this car new in April 2001.
The complete package has costed me in excess of $100,000 to build.
TOO MANY TIME WASTERS, TOSSERS, TYRE KICKERS, WANKERS, DICK HEADS, DREAMERS ETC. CAR IS OFF THE MARKET FOR NOW. PROJECT Z COMING SOON TO MELBOURNE.
Guys i was with Damian this weekend and went for a run in it. This car is unbelievable!!
I really want him to keep it, but he wants to move on. The car has no lag and on boost is just a sight to see. My liner has 220rwkw and all i could do is watch this s15 tear me to shreads!! (with him granny shifting i might add!!)
Has it still got the standard 6 speed?
Still standard S15 6 speed. If i was to keep the car, id put a os giken gear set in it, and take it to the track and run a very low 11 or possibly a high ten if i can get the granny shifting outta the way haha.
Thanks BMT.
I have a few questions to ask:
Why was the engine rebuilt after the major enhanced build??
Did you get a new block or use the old one and rebuild it?
Has the block been prep'd at all? eg sleeved?
Is it the s15 engine which is built or an s15 block with s13 head (sorry cant tell from the pic)?
Thanks BMT.
RNS11Z- what do you mean why the engine was rebuilt after the major enhanced build? The motor was only built once. It has the original block and head from the s15. Previously at the autosalons and auto expos last year and this year, it had another s15 spare block which had more of a subtle set up with arias pistons and eagle rods. This spare block was used for R&D purposes and then the new block (original one from car) was put in with all the JUN parts.
At first I was told by the engine builder that the block was O ringed and sleeved, but found out that it had only been sleeved.
As admin has stated - if you arent interested and dont have the means to purchase this car, please dont post replies on here and waste my time. Admin has already stated that banning people like this from classifieds will take place if this happens.
bump - open to reasonable offers now. Or if you have a friend with a S2000 or GTR33 Vspec 96/7 above or a worked GTT34 or you own one of these, ill be willing to swap plus cash adjustment. Need something that is less angry to drive to and from work through the city.
  • 4 weeks later...
bump - open to reasonable offers. Im about to list this car in the trader soon. Still open for trades with S2000 / DC2 Type R or Gtr33 Vspec 96 above.
304rwkw at 20 pounds @ Race Pace last month.
bump - anyone that pushes this sale to any potential buyers will be rewarded considerably. Call me on 0400255008. Cheers. Price can be dropped if certain parts are removed - buyer will be responsible for replacing parts on his/her own account.
    • UPDATE: Hi all!  As we are getting towards the end of this thread where I’ll showcase final dyno numbers and graph, I wanted to provide an update. Tao from HyperGear has done an amazing job building the custom divided T3 housing for the G30. Communication was flawless, price was great, and now the housing is estimated to arrive in 7-10 days! Very very pleased. I must add, if someone is looking for an affordable turbo and end up reading this thread, I would recommend HyperGear. Genuine brands are the way to go as their proven reliability, predictable performance, and there’s a plethora of information available for specs, flow, and more. This HyperGear recommendation is based on their excellent communication, dedication, and willingness to listen to their customers. I particularly liked their ability to create custom adaptations tailored to specific needs, which is a HUGE benefit over other brands. And if we consider the HyperGear provided dyno results, it adds reassurance knowing their turbos can compete against genuine brands. Next update will be after the dyno!
    • I've previously seen people post up "dress up bolt kits" for RBs but don't remember seeing them specify the full contents. I can only really suggest you grab the verniers and start measuring, and keep in mind the cam cover and timing cover bolts are both quite specific with a wider unthreaded section where the bushes sit, that will make it hard to get aftermarket replacements which tend to be all thread (set screws) or for longer bolts a flat section with a shorter threaded section at the end
    • I believe there was a similar one posted by @duggyphresh. They were re-routing their battery positive cable in the way I am also trying to achieve. Sorry, I’m new to this forum, so was a bit late to the party by a few months and so reignited the old thread, as I wanted to know how they got on with doing it.
    • Wasn't there a thread on this very subject just a few weeks ago?
    • Hi all! Looking to relocate the battery to the trunk of an R34 GTT. I want to do it using as many stock GTR components as I can (including the harness protectors from the 34 GTR that run underneath along the chassis to the engine bay). So far I’ve purchased the battery tray from a 33 GTR, as the captive weld nuts are already there just asking to be used. There is also the slight issue of now having to relocate the ABS/TC/Fuel Pump Control ECU, which in GTT’s sits right above where the battery will then sit on the tray. Has anyone already achieved this, and if you have any pics that you wouldn’t mind sharing? It would be great to see how others have done it and where you put them, as there are countless holes in the parcel shelf panel to potentially use. Just trying to get some ideas bounced around, and to help uncover any potential problems I may encounter by  my choice of location. TIA for any help!
