Upgarage.. where are you located? looks like sydney in the photos! i have seen a sprinta similar to that colour at my mechanics... but i think that was gonna use a 20v or std 4age with side draft webbers etc..
that was gonna use 6pot brakes and stuff too!
have you sprayed the outside of it yet? are you using for street or just drag/track?
  • Replies 154
bought foam from clark rubber today to sculpt a bodykit out of which I'll then make a fibreglass gelcoat negative out of.... custom bodykit begins after new years'.
  • 1 month later...
lol no red ... silver
and yeah these things are noisy enough.. so it has been sound proofed .. adding a rebuilt s15 tturbo .. new plenum in pics, diff just been rebuilt .. getting there slowly :D
Looks like I will be getting a daily driver AE86 and leaving the r33 gtst in the garage
AE86 comes with met brown faded and flaking paint, white bonnet, rust in the tail gate and a blown head gasket
Has 5 speed and Air cond :)
$300
Have not decided what engine to put in
My last car was a AW11 MR2 with black top 20v and motec M4 but cost got too high. I think I will put a 20V silver top and factory ECU.
so you want a N/A engine in it? There was a pink AE86 drifting at wakefield on the weekend, NA 4age .. was going good but something broke, needed more power fo the long, high speed corners.
what price can you get the 20V with gearbox and loom for?
I have not started looking for a engine yet
My blacktop 20V in a front cut and auto box with 13,000km cost me $1850 about 6-7 years ago. Was only about a 12 month old motor at the time. It took me 6 years to get the MR2 on the road (got married and bought a house :) )
Silver tops are anywhere from about $600-700 plus
I will probably use the box that is in the car and just get a complete 20v with ecu and afm for approx $1000
not progressed coz its a low priority...
we're spending some time recently trying to use the old engine that we took out of the car (4ac) gonna make a blow through carby turbo, with the carby housed in a pressure chamber to avoid fuel backflow. plus some thick head gaskets and piston shaving to reduce compression should see a nice engine ready for another AE86 shell :)
what about reinsforcement of the float so it doesn't implode ... prety sure i've heard this happen on blow through systems.
do you trust the gear set for the 4ac to cope with that power..
same thing for you Darrin.. i dont think the gearbox from the 4ac will handle the 20v 4AGE power and revs etc.. i havent looked into it, but wouldn't think so from looking at the one we took out of the sprinter here!
The gearbox should be OK
The 20v only has about 120kw at the engine and not alot of torque
13 years ago i had a TA22 celica with a worked over 3TG twincam a that had more power and torque than the 20V. They use the same gearbox.
That box lasted over 2 years of constant thrashing (I was 19 :) It did eventually break 2nd gear. Went of the wreakers and bought another $250 g/box
If I was to turbo the 20v then i would start to be worried about the box.
fair enough darrin, they just look pretty weak is all. shame we gave away and exedy clutch that was in the car we bought, no use for it.. the block had 2 holes in it. damn rod went for a trip around the block lol
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
