  • Replies 154
y0 craved, my engine mount for the CA18 seems to be showin some stress due to engine twist. My fault I guess for doin some ghetto welds ;) How much is the full engine and gearbox mount kit from where you got it?
ok, the brother of the owner and i created a new one for the passenger side, the easiest thing i could suggest you could do is to create a JIG from your existing one including templates for the end plates, hole locations etc
this would allow you to get these done extremely cheaply. and be easier than us designing them for you since we are using engine mounts from a jap spec corrolla (dont ask - they were already on it)
take the JIG and the existing ones to an engineer, this would allow them to ceate them without having to work it all out, hence they just cut the steel and welding it for you.. would be stronger and the they wouldn't have to spend much time creating them. which will make it cheaper. take most of the labour out of the equation.
the gearbox mount was simply a standard gearbox mount with the centre modified and a reinforcement plate welded to it to align with the mounting holes on the ca18 box ... not too much work involved, although the gearbox and everything is back in the car so i cant get photos for you.
we have welded the new rear quater skirts and tailgate back on to remove the rust, the modified lower control arms have been lengthened and reinforced .. they are bolted back in , just waiting on the new custom sway bars to arrive. adjustable strut tops are in place.. just have to find a shock setup to allow a high level of lowering while maintaining a wide range of motion before bottoming out.
can you confirm if the front suspension of an MR2 is usable on these?
oh and use a higher grade of steel on the engine mounts.. what rubbers are you using? try and find something that has a harder compound.. as ours are a bit soft to cope with the ca18's power/torque movements.
  • 5 months later...
hows your Project going Shan ??
considering buying one myself as a daily driver...
the one we have been working on has just been prepped for respray.... welll its been primed and waiting for the sanding back... then spray..
should be going candy red for it, i just wish the owner would get a body kit for it before it gets sprayed.
you know anywhere to gets kits for em?
not as fast as I'd hoped unfortunately... the engine will be put in sometime this month. I've been fixing up the little niggles and stuff on the R32, coz I'm looking at selling it soon, so the AE86 has sat in the back of the workshop for the last couple of months gathering dust.
Me n inark are dabbling in some fiberglassing so we can make our own custom kits, but at this rate it might take us over a year :(
CA18DET, with CA18 gearbox, T18 diff and TRD 2 way LSD. Ended up deciding to try and adapt the S13 engine crossmember to fit onto the AE86 chassis, and at the same time mounting the S13 power steering and steering column in rather than using the less than inspirational toyota one.
sounds like a little extra work with the S13 crossmember... but atleast then you would be able to use the STD. engine mounts.
whats mods you have to do to use the steering column through the AE's firewall??
dunno, will let you know when we get around to it :mellow: still trying to fit the cross member and make the suspension fit.
Worked out easier tho, all I had to get was an S13 cradle without engine, and got all the parts. Also means I'll get to use standard S13 bolt on suspension parts and have a smaller steering wheel lock.... and power steering :)
drifting was on Foxtel on inside speed. Yellow 86 would be crab methinks.
and yessir... that would be my 9 piece BN Sports Widebody kit being test fitted. 50mm on either side. The wheels on the car are stock silvia ones.
siiiif I'd waste my time on an S13 (the AE86's gettin most of the S13 parts anyways). Besides, with all the kids running around in widebody S13's S14's and S15's I need something different.
Its for my R32, and no it'll be done sooner than 2 years, maybe next year or something. lol I cbf.
Here's the finished product on a car in JP.
    • I've heard the Tomei USA head gaskets are decent if you want to o-ring the heads but otherwise not recommended.
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
    • Since winter isn't that harsh anymore in Poland, i will definetely drive it 365 days a year 馃槈. But if the snow hits i will try it for sure and let U know. Only swap i am planning to do is of course R34 GTR front 馃槏.
    • Hey. Very valuable information about pitwork, I will pay attention when buying any consumable parts 馃檹 As for the carpets - I got a handful of information from nengun, from which it appears that indeed the carpets for the driver's side are OEM. They are not able to show me any pictures due to the long chain of different sales entities but after I place the order, as soon as the goods arrive at the nengun warehouse from which they will send the shipment to me they can send me photos and if my purchase differs from OEM I can immediately return it / cancel the purchase. I think I will give it a try 馃槈. Of course i'll let you know what's what as soon as i get them P.s. I know the topic is not relevant to the thread, but both nengun and amayama have these SICK 馃槏 trunk room lamps available. Do you know anyone who ordered them? I need to have one in my car
