Hello Everyone .. I am wondering if someone can advise/help me with this problem .. I have a in dash 6CD changer/radio/cassette .. taken out of a 200sx specR 2002 model Nissan .. minus the wiring harness. The person I bought the radio off said the harness could be purchased and or fabricated easily. So far I have tried 6 audio installers, Nissan Spare Parts, and a couple of wreckers trying to get to the point of installation .. the only information I have received is that .. 1. I NEED the harness for installation and color coding etc .. 2. That my best bet would be to get one from the wreckers .. so far I have not tried too many wreckers, believing that there would not be too many in the wreckers( I could be wrong on this point)
So .. what I need to know is .. does anyone out there HAVE one I could buy>?
and what other model Nissans maybe came out with the same wiring harness>? IF any ..
Thanks for reading and I would appreciate ANY advise ANYONE might be kind enough to give me ..
(IF all else fails, the option of shooting the guy who sold me the radio is not out of the question :headshot:
https://www.sau.com.au/forums/topic/54510-200sx-specr-wiring-harness/
Try Nissan? Try a car parts store like Autobarn, or a car audio store (Strathfield)?
Failing that, you can pick up a replacement aftermarket harness from somwehere like EBay.
Another point of help is the Install Doctor (www.installdr.com). Has pictures of wiring harnesses used in common models and you might be able to find a similar one.
Thankyou raz0r$harp for your suggestions. Alas .. Nissan do not sell them. Autobarn either, although they are supposed to be a dealer for Aerpro, who DOES sell them, or at least there web site says they do, but I have been unable to get a reply from them, so I think they have re-located .. or something.!?
Ebay is where this started, I bought the radio off ebay .. :Oops: :Oops:
Never mind .. will keep looking, the install doc was a good suggestion, I will follow that up, thankyou for giving me their site URL.
Cheers .. Pam
send me a picture of the  units back end. nissan have two variants of plugs. I have both  on hand. the car description isnt enough.
Hello Cris, thankyou for taking the time to reply, much appreciated. I have sent off a mail to you with particulars and photo.
Regards ..
crazyyone
;):P
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
