Simplest is to rotate the G-sensor module through 90°. The G-sensor is the gold coloured box located under the centre console, in the very middle of the car. Rotate it by 90° and fix it in its new position. Advantages: results in a far higher degree of front wheel drive torque split in cornering conditions; is the easiest of all modifications. Disadvantages: results in some wheelspin in straight-line acceleration at high revs; power understeer can occur; in wet conditions the car is still a little unpredictable. Summary: Gives an easier car to drive but isn't the ultimate mod.
This Mod is inly if your serious
With the G-sensor orientated as factory, disable the output of the lateral (cornering) G-sensor. This G-sensor input actually reduces the front wheel torque split as cornering loads increase. Cutting the wire results in a fault condition and the disabling of the four wheel drive and ABS systems. Instead, 2.5 volts needs to be constantly fed to this ECU input. This can be achieved by using a voltage divider (pot) as shown here. The pot should be carefully adjusted until 2.5 volts output occurs when it is connected up. Advantages: very large amount of front torque split in cornering; simple mod; superb in wet conditions; excellent straight-line traction. Disadvantages: excessive power understeer in dry conditions. Summary: great "wet weather over-ride" if switched in and out appropriately.
https://www.sau.com.au/forums/topic/54560-lateral-g-sensor/#findComment-1067498
Guys;
This is exactly the type of path that Julian Edgar took when he did his famous article for Autospeed. I think it's on here somewhere so a search under torque split controller should produce it. Details different approaches, pros and cons of each etc and gives a circuit for the configuration he settled on.
Good luck.
https://www.sau.com.au/forums/topic/54560-lateral-g-sensor/#findComment-1068281
i remember that he removed the g sensor and replaced it with an amplified signal that was adjustable with a controller in the dash so he could adjust the torque split for different conditions.. one click each for dry, wet, really wet etc ... good article would be handy on cars in improved production for more tunability for all conditions...
do you know if this would be allowed in that class Duncan???
https://www.sau.com.au/forums/topic/54560-lateral-g-sensor/#findComment-1069377
We have an HKS adjustable torque split controller on our Improved Production GTR, there are no problems with having an external ATTESSA adjuster in the regulations. The Production GTR has adjustable torque split control via the Standard ATTESSA ECU which has modified software, software is free under those regulations.
Hope that helps :)
https://www.sau.com.au/forums/topic/54560-lateral-g-sensor/#findComment-1070000
If anyone is interested i have made up a few torque split controllers using a pic chip with an inbuilt anologue to digital converter for the input side and using pulse width modulation on the output, basically what it does is look at the input voltage and puts out a modified output voltage depending on what setting it is in. it works the same in principle as julian edgars one but is in a fairly small package 40mm * 70mm * 25mm. It has 12 different modes, mode 1 is 1:1 outputing what it sees on the input from g sensor no change from standard setting voltage swing, mode 2 is 10% degradation of the voltage swing upto mode 9 which is a 80% degradation of voltage swing, mode 10 feeds a constant 2.5 volts into the attesa taking away the influence of the lateral g sensor altogether, the other 2 modes are for two wheel drive. the first one feeds a voltage of around 3.5 volts into the attessa which tricks it into beleiving it is going around a sharp corner so biases the drive to the rears, in my gtr i have done a rear wheel spin in a straight line in this mode for about 30 metres before the fronts kicked in so it makes the car very taily, the final mode is just the same as pulling out the 4wd fuse, it is then just constant two wheel drive but also knocks out the abs (same as pulling the fuse) and the car must be switched off and then back on to get it back to 4 wheel drive mode. In my car (r32 gtr) i use the radio control buttons on the left hand side of the dash (am/fm & tuning) to switch up or down the modes and a 5mm led which flashes out which mode it is in. I have had it in my car and a friends gtr for around a month now and it is performing very well to date. I will be fitting one to a r33 gt-r next week, though i dont expect the difference to be as much as the with the r32 gtr but it will be interesting to see how it goes. The box itself is small enough to fit in the console near the g sensors.
https://www.sau.com.au/forums/topic/54560-lateral-g-sensor/#findComment-1070931
interesting, I didn't realise you could get at the atessa software...got any more info?
The ATTESSA ECU came from Mines, it has 4 settings, #1 is rear drive only, #2 is ~20% front drive, #3 is 30% front drive and #4 is ~40% front drive. The G sensors are still there but don't do anything. The car has a Motec ECU with launch control, which switches from #1 (just to get the rear wheels spinning) to #2 then #3 then #4 (if the straight is long enough). Once the gearbox is downchanged, launch control is automatically turned off. This means it stays in #2 or #3 depending on which we choose before the race (ie; it doesn't change). We only use #4 when it is really raining. Note that this GTR has all homologated Group N stuff, ATTESSA clutches, front and rear LSD's etc.
In Production Car Racing we are not allowed to add things like switches or external controllers, so everything is done by software. It doesn't work as well as the switchable HKS controller in the Improved Production GTR, but better than nothing.
Hope that helps:cheers:
https://www.sau.com.au/forums/topic/54560-lateral-g-sensor/#findComment-1070962
SK ... have you found it making a noticeable difference at that level of tuning?
Oh it makes a difference all right, but it also adds another level of complexity. On the Improved Production car we have adjustable stabiliser bars, quad adjustable dampers (high speed & low speed, bump & rebound), adjustable ride height, many sets of springs with different rates, full adjustment in the suspesnion geometry, camber, caster, toe, anti dive and anti squat. By the time you add in adjustable drive, my brain aches trying to tune it.
An example, it has low speed oversteer. Bit more front bar, less rear bar , higher rear roll centre, more neg camber on the front, 1 click on the low speed front damping, 2 clicks on the high speed rear damping and then change the drive 2.5% more to the front. Damn now we have high speed understeer. Around and around we go.................... :headspin:
Too many things to adjust and not enough time, make that NEVER enough time to try them all. :boohoo:
https://www.sau.com.au/forums/topic/54560-lateral-g-sensor/#findComment-1070964
    • Hey was wondering if you ended up installing the R33 GTR speed sensor - I found one too and wanted to confirm it's a direct swap into the R34 6 speed?
    • After 23 years of owning a Skyline, finally had the latch go.  Followed this guide,  works like a dream again. Great Guide 👍
    • Hi all,   I’ve got the biggest lot of problems with my R33 GTS-T   It was a freshly rebuilt 25th anniversary RB25DET (plastic cas, neo cams) probably 6 years ago now   The engine was running so well but I fkd up badly and trusted someone I’d known for 10 years that was well known around Plazmaman for his welding and fab work. I added a lovely photo of some of his previous work. Not sure why my car was worked on by whoever did this shit     I’m normally someone who would never open myself up to something like this, I still can’t believe I did it. Trusting him literally fkd it all up for me. Everything has been a struggle, like it’s almost been 6 years that’s how much I’ve just on and off been trying to work it all out.    All I wanted was a car that danced down low, like full boost from around 3~3500rpm to redline, don’t really care what power it puts down (if it ever does) but I just wanted it to be quick to get on it.    He recommended the turbo to get, I picked Hypergear but he told me to get the front 4” with a T4 and 0.68 rear housing.    I was expecting all these beautiful welds, tidy fab work and paid for it to be ready to go to a tuner when I got it back.    I got a car back that was an absolute mess, I actually couldn’t believe it was my car anymore. I don’t think you could even call what he did welds, they’re disgusting.    So I stripped everything he touched off it and with every bolt I loosened it just got worse and worse.    I covered it and literally built and finished another car in the meantime but now it’s getting to the point where I really want my Skyline back.   Its a struggle because I paid him to do all this shit because I didn’t know how to and now I’ve had to try and figure it all out omg    Please excuse the bird shit horrible welds, I’ve got my show pony car and am so beyond dealing with this car I don’t even really care at this point.    If someone told me about what he did to my car I wouldn’t have believed them but it happened to me. It was unbelievable. He went missing, my car went missing, it came back missing parts, the straight af chassis rails bore the scars of being dragged up a trailer backwards, even the sandwich plate was bent. Everything was leaking and open to whatever fell into it, rounded off/ missing bolts, power steering oil and coolant everywhere, no gaskets, parts stolen off it, even managed to damage the sump pan.   Promised me he’d finish the car, knew what it meant to me, I paid him thousands and thousands just for him to trash it. He told me he was fully licensed and insured, come to find out he’d cancelled his ABN, so obviously no insurance. I had laid up insurance on the car and would’ve been covered but I was scared they would’ve written it off or because the business was no longer trading I’d still be liable.    He was supposed to:  New fully custom mild steam pipe exhaust manifold with turbo location moved from factory position to high forward mount. (I don’t know if it is a mild steam pipe, I’ve got a funny feeling the waste gate isn’t in a very good position and I don’t think the outlets off each cylinder are equal) 4” custom stainless steel dump with external gate (he re-plumbed it) Cut and shut OEM intake manifold with throttle reposition (I ended up doing the throttle reposition) Box in pod filter (left out) New 100cel catalytic converter (pretty sure it’s there but unsure if it’s 100cel) Front mount intercooler piping fabricated to suit (all smashed up and rusty holes where he was supposed to make it look standard where fmic piping passes through. I don’t even think my front bar is going to fit 🙄) Custom 5” intake pipe from pod to turbo (didn’t come with it so had to do something to make it work with the Z32 afm)   Engine: Full cylinder head service & machining  Brand new valves Precision upgraded spring kit Engine block honed New bearings  New piston rings  New ARP conrod bolt kit New ARP head studs Cometic head gasket VRS kit   ATR43SS2 ball bearing turbo 0.68 rear housing  Turbosmart 45mm external wastegate (got delivered to the fab bloke, I’ve got no idea what spring is in it, I’m assuming the one that came pre installed) Walbro 260 fuel pump  Nismo 740cc injectors (tested to 880) Spitfire coil packs GCG FMIC RB25DET manual 5 speed 4:11 rear diff   I’ve got an Apexi Power FC in it atm, I was hoping to just get it to operating temp to make sure everything was okay before towing to a tuner but it’s over-fuelling too much. I don’t think that’s going to happen so i think I’m going to get either a Link G4 or Haltech for it. What do you guys recommend? I can’t work out the power FC so just gonna give up on that one     It’s got an exhaust leak coming from somewhere I can’t see 🙄    The fuel pressure was steady but now it like drops from 40 to 20psi randomly (noticed this yesterday)    I’ll attach pics of the shit he put on my car and the engine bay now as it sits    I really just need some help, I need a tuner in Sydney I can trust, I’d like to be with the car while it’s being tuned if possible, I know it looks terrible but unfortunately I’ve just got to put up with it for now and fix the cosmetic stuff later   Do you guys think the manifolds are going to be okay? Or do I throw the exhaust manifold and try again?   I don’t even think these combinations are going to work tbh   I know everything I fitted was rated to be able to take at least 400kW but most rated higher    If you’ve gotten this far I really really appreciate it 🙏 I don’t mind if you trash me or the car, I made a rookie error and f**k I’ve paid for it. As you’ll see 🙄
    • From everything I’ve heard you’ll be waiting a long time for  the parts to arrive
    • Have you looked at the workshop manual?
