import an 89 model while you still can, or buy a 90 model for import next year..
theres a misconception that 15 year old cars are 1000x crappier than a car that is only a handful of years younger than it. The truth is that 15 year cars are just a few years older than the cars that cost 4-5k more.
And if you find a 15 year old vehicle thats in outstanding condition its not uncommon for it to be a far better buy than eg a 92 model that has average amounts of wear and tear.
I have owned 2 now. My first was a 92 model and I currently own a 93.
You really need to take a good look at the inside of the car to get a good indication of the condition. You will know what I mean, when you start looking.
Under the car can also give a good impression.
So there is no real interior difference? So what are the differences? What about the studs on the wheels i have heard something like the later models come with 5 or 4 or something like that any of u guys know about this?
First of all, you should go for a Type M (as opposed to a standard GTS-t - Type Ms have the "Nissan" 4-pot front calipers)... not that you'll find a normal GTS-t floating around anyway but...
The interiors on the later (post '91) GTS-ts ditched the smooth black plastic surround that goes around the audio system/air con controls for a "grained" grey plastic trim (can someone confirm? I bought a grained plastic surround for my car off Yahoo and it was from a post '91) and the seat fabrics are different afaik. The standard audio system was upgraded, but I think most R32s have had their audio changed for aftermarket at some stage in their life.
All Type Ms have the 5 stud hubs on them....
I have a 1990 model btw.
Just my 2c, but I really think you should get the latest model you can find with the best bodywork. Especially check the rear wheel arches for rust and where the rear bumper attaches to the bodywork... a haven for rust. Rust is the killer, you can change the engine, replace the interior WHATEVER... but you can't stop the rust without doing it properly with alot of $$$ that you could be using for performance mods. I love my R32 even though it's been abused like a 2-fitty hooker, but I would go back and do it again to get a more expensive well maintained (and rustfree) 1992 model.
You cant import from around 90->mid 92 because the R was sold in australia during those times.
Also, the type-M was only from around 92 onwards (Series 2) also wasn't it? with LSD, 4 pots, kit etc.
Shaun
well your making the right decision by buying an R32, i've got a 92 type m gtst.
its a nice little car that likes to kick out the rear some times around corners, hehe
With the fuel consumption, if you drive miss daisy it wont drink anything, if you drive like schumacher it will much like any normal 6cylinder turbo vehicle. I've found that running BP ultimate is the best fuel for this type of car and you get more k's.
-B
Shaun
Type Ms were released from May '89 through till July '93... all of those Type Ms had the 4pot brakes and LSD.
Shaun
Yours is a '92 though isn't it Shaun? How did you get it?
Cars built from june 92 onwards could be imported through the old scheme, and will be able to be imported through the new scheme, if anyone gets approval for them.
Pre 91 cars have blue dials, post have grey dials.
My 92 type M still has the stock tape player.
All turbo skylines R32 onwards have 5 stud wheels.
Not all type M's have the bodykit, it was a factory option.
my 92 model has blue dials
i'm thinking the dial colour was dependent on the car colour as my car is dark blue to match the dials...
most dials are grey as most cars are grey/black
I'm with Rezz, get a Post Aug 1991 (so that's a series 2) Type M. You'll get all the factory goodies that you want and a car that didn't have any recalls.
Post 91 cars ot grey dials, blue only vame from NISMO, apexi, and other aftermarket dial makers or factory in Series 1 R32s
Dunno if you'd want ABS, but yeah see if you can get a sunroof... its a bitch to put a sunroof in a R32 afterwards, and its soo nice in summer, as you can leave it open when you leave the car and it dosen't become a sauna.
Make sure the leather on the dash isn't lifting as this is a common problem, also around the C-Pillar the leather tends to split and peel off. If you find one that doesn't show this then its a sign that the owner was very careful with his car and took care of it.
No, no... RHETT is right, post-'91 cars have grey dials, I think your dash has been replaced Warren *runs and hides in the corner behind the sofa*
aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaah
well it matches the paint so who cares?
(anyone got nissan FAST so i can check my build date?)
    • They also make them with the motor mounted on the side
    • Just be warned that that turbo will not be a direct re-fit to the car. The exhaust housing is, of course, in the same place. It has to be - it's bolted to the exhaust manifold. So the dump will fit up. But the centre housing is not as long, so the comp housing will move backwards. This will affect both the turbo inlet and the outlet. There is fab work that needs to be done. Yes. it has one, it should have one. Paper gasket.
    • I only recently purchased the vehicle, it came with the flex setup but the current tune is e85 only, which is why im wanting to get the tune redone to enable a mixture.  First i need to get the exhaust redone tho. I was thinking of getting a varex muffler but it sems they dont fit well in the 33 (hang low because of the valve mechanism which sticks out on top) and generally dont sound good. So that leaves me with redoing the entire exhaust (more resonators and mufflers) so its not a menace when i come and go from home, and then have the aes dump valve somewhere along the line to really open it up. I was thinking of having it before the cat but after seeing how insanely loud it will be (on a vl turbo) im thinking of putting it more towards the rear of the car, after one of the resonators.
    • At this point I'm just 'hoping' it's the turbo seals. I did speak to someone who said it's normal for these turbos to have a bit of axial play? Not gonna lie I've never checked a turbo for axial play before but you could hear it tapping a bit as I moved it back and forth. Surely that's too much? My theory is (could be completely wrong), bad axial play, worn bearings, bad seals, oil into dump/compressor side, burns in exhaust = blue smoke. On a timing belt related note, my crank pulley was missing that front plate that sits in front of the timing belt. It's that metal round plate. It did have the rear one, and the woodruff keys are in the crank which was nice. Can anyone confirm if the NEO det engine has a front plate, im sure it would to protect the front of the timing belt or something. Water pumps...the pump I got was an NPW (yes grill me if I should've got a genuine one lol). It has a smooth mating surface, kit came with a pretty pathetic looking paper gasket. Do I need to use any RTV or just trust the gasket will work because its a smooth mating surface? Cheers legends have a good Easter break!
    • Cheers man, I thought the same.   Bit of an update on it all. It was definitely blue smoke, not grey after all. It didn't really smell oily but it was blue after all. Also puffing just the smallest amount on idle with no throttle.   I ended up pulling the intake and exhaust off and there was around 3mm of axial play on the turbo shaft. So I figured we'll that's buggered and sent it off to get hi-flowed at hypergear. Haven't got it back yet.   I haven't compression tested it yet. Had a look in the cylinder and cylinder 1 spark plug, looked a bit sooty but not oily. Then I've just started doing my timing belt because it's age is unknown.
