I want to swap my front brakes for R33 brakes, I have a few questiosn that hopefully I can get a few answers on -
1) Is it just a case of swapping the calipers and rotors for the R33 ones?
2) Will the stock R32 master cylinder be ok
3) What rotors should I run - new stock or something a little better - will be using Racebrakes RB74 pads
4) Will they fit behind the standard rims?
5) Is there any other things I haven't thought of?
:D Chris
https://www.sau.com.au/forums/topic/54646-33-gts25t-brakes-on-32-gtst/
Some info on brakes, master cyliners and rotors
R32 GTST
Master Cylinder diam (mm) - 25.4
Front Caliper Piston(diam x qty) - 40.4 ×4
Front rotors (diam x thk) - 280×30
Rear Caliper Piston(diam x qty) - 38.18×2
Rear Rotors (diam x thk) - 297×18
R33 GTST
Master Cylinder diam (mm) - 23.8
Front rotors (diam x thk) - 296×30
Now the interesting bit...:P
R32 GTR (Non V-Spec,)
Front rotors (diam x thk) - 296×32
R32 GTR V-Spec / R33 / 34 GTR with Brembos
Master Cylinder diam (mm) - 26.9
Front Caliper Piston(diam x qty) - (44+38)×2 ... leading pistons larger then trailing
Front rotors (diam x thk) - 324×30
Rear Caliper Piston(diam x qty) - 40×2
Rear Rotors (diam x thk) - 300×22
So there isnt much difference between the Brembos and the std Nissan R32/33 GTST calipers and R32 GTR calipers.
If you want a brake upgrade id say go grab some DBA4000 meant for ther GTR , which are 324 x 30mm ...(DBA5000 if you can afford them) All you will need is a bracket to offset the caliper to suit the larger rotor.
Id stick with the std R32 GTST calipers. R33 calipers look better but hardware wise i think you will find they do the exact same job:)
Cheers for the info mate, the big thing for me is that they HAVE to fit under my 16" P1's, other wise there is no point me upgrading.
The main reason I want to go for the 33GTS calipers is so I run the bigger disk without fouling the rim, and being that bit bigger, hopefully they will do a decent enough job
Currently I am running some type of slotted rotor and racebrake RB74 pads, they work well, but I think with a bit more grunt and a upcoming driver training/track day early december, something a bit more substantial is required
What do you reckon?
O would not see any issues fitting the R33 brakes behind your 16" rims........R33's came stock with 16's, depending on the offset of your P1's you may require small spacers, simple fix.
If you do go ahead with this i would be interested in purchasing your R32 discs and calipers.
Cheers
Cheers
I will be going ahead with this, as I have already found some calipers and paid a deposit, just need to know if its going to be a simple task :D
PM me if you want mine and we can sort something out,
regards, Chris
Id use DBA 296mm rotors. The R32 GTST caliper is the same as the R33 GTST caliper isnt it. If it bolts to the hub and automatcally clears the larger rotot then fair enough, but im not sure if that will be the case. Intersting to see if the hub is different or the wings of the caliper are different
Larger master cylinder means the piston is bigger, sdo for say 10mm movement pisplaces more brake fluid so in theory should equate to a little more pressue in the lines?!?! I think, not 1000% sure
I know that the R32 caliper will not accept a 296mm rotor, tried that already :) from what I can see, the R33 caliper is mounted up a little more to make room for a bigger rotor
From what I can gather of the wrecker I am getting them of, its a simple case of unbolting the 32 calipers, put the 33 disc on and caliper and that should be it
I reckon you are pretty spot in re master cylinder stuff
Chris
They are bolting everything back on now, pipes and other shit, and tune is happening now I spose. I am leaving here in about 40 mins to go and hopefully see the final tuning etc and drive it home, Shaun reckons it should be all done by about 7ish, as they have to get the car out to make way for a few more booked in for tomorrow
Bummer about your car, at least they are not giving it to you until they are happy with it, should be great mate! :D
the rear disc size is 297mm as Roy says hehe
btw, R32 GT-R discs have angled cooling vanes in the middle, compared to the straight vanes of R32/R33 GTS-T discs. That, combined with its extra thickness and 296mm size, gives it better performance over extended track sessions (>10 laps). The R32 GT-R caliper is physically bigger than the R32 GTS-T's caliper, similar size to R33 GTS-T but slightly different design.
    • Yes. It's either "2 wires", or 1 wire, depending on how you look at it. It is the connection that ties the battery -ve to both the chassis and the engine. Every electron that goes in or out of the battery goes through those 2 small spots (on the inner guard and on the engine block). If those are not clean and tight, then shit starts to suffer. Yeah, but measure it again cold in the morning, after it has had hours to rest. You can't usefully test the charge state of a battery immediately after it has been running because the alternator puts a surface charge onto the plates that takes a while to soak in and balance out. It will always read higher, and potentially look properly healthy, when fresh off of charge. But hours later it can look a lot less healthy. It's also worth measuring the battery voltage while cranking, although this can be difficult with a typical DMM because the screem update rate is so slow on most of them. An analogue voltmeter is actually a better tool for that. If the voltage drops too far while cranking, it is a sign of a poor battery. Although I don't think we're necessarily looking for a weak battery here - just wanting to exclude it.
    • https://www.facebook.com/share/15ZMn5oXtc/ Updated Event (so its not private and can be shared easier)  Attempting to coordinate a big push of Stagea's to this years GTR Festival. Great event last year and hoping for the same this year.  Discounted tickets 20% off for their various tickets until the 3rd of Feb Monday. Drags, show and shine etc.  I've emailed them to ask to set a location aside for the Stageas for the show and shine - they are happy to do so if we can get them numbers, I'm happy to keep track of that. Entering as Nismo category.  I'll be road tripping up from Melbourne, would be cool to convey if people are interested, maybe there is SAU convoys from each capital? If you have ideas about that let me know.  https://gtrfestival.com.au
    • Does have series 2 airbag steering wheel and passenger side airbag also.
    • Do I have a series 2 or has someone spent money to have a series 1/1.5 look like a series 2? Everything I have read says the series 2 came out in 1996. I have a car manufactured in December 1995. The exterior, engine and interior are all series 2 other than the dash facia is series 1. Paint code is also kr4 that I believe is only available on a series 2. I have a VX Vehicle History Report and it says Grade: GTS25T TYPE M2 Manufacture date: 1995-12 Make: NISSAN Model: SKYLINE Body: E-ECR33 Grade: GTS25T TYPE M2 Engine: RB25DET Drive: 2WD Transmission: F5
    • I went to Repco to get them to test the battery using their tester (not a volt meter), alternator shows 14.3v when running, and when the car was off after the it was on full load I think it was 12.6v but the guy said it was all good. Terminals are all clean, no corrosion. Though I coulda sworn when I tightened up my alternator belt the car idles a bit higher and the steering wheel shakes a bit until it's warmed up. I wanted to confirm for the earth cable/s, are you referring to the 2 wires that are bolted onto the frame rail under the battery? I might be overthinking this a bit.
