hey guys,
after I start my gts25t from cold it makes a kindof bearing noise whine, (I think) it's not too bad but noticeable. After 5 mins it goes away.
The noise changes with the revs.
I thought it was the gearbox, but it still does it when I push the clutch in.
Also thought it might be the water pump/alternator/a/c/power steering but don't think its that cause it sounds like its coming from the back of the engine.
Any ideas what it could be?
The engine has done 130,000kms, seems in good condition apart from that.
It's standard and was automatic until last year so don't think it has been thrashed.
The fuel pump, afm and water pump have been replaced. (previous owner said)
Can I put a metal rod onto the engine somewhere to "Listen" to the noise to figure out which bearings it could be? Whereabouts would i put it to listen to it?
Is it hard to replace bearings inside the engine? Do they cost a lot?
I'm mechanically minded, done gearbox changes etc but haven't opened up the engine before.
Also do 25t gearboxes cost much for bearings? Can you replace them yourself?
I'm worried if I leave it, it might stuff up the whole engine.
Dave
https://www.sau.com.au/forums/topic/54651-bearings-bearings-bearings/
hi, check the following.
press clutch pedal in about 10mm, if sound goes away it is the thrust bearing that presses against the clutch fingers.
press clutch all the way in, if noise goes away it is likely to be the layshaft bearing( at front of the gearbox)
other bearing noises are as you listed and also the cambelt tensioner bearings. can listen to cambelt cover with a screwdriver handle to your ear - assuming of course you dont have long hair etc that will get caught in fan...
I replaced mine about 140-150000kms on my RB20det, one was fine, the other sounded raspy and feels rough when you spin by hand - i replaced both. If you can do it yourself you should be able to get the bearings for under $200 pair.
Stephen
Also, if you used a new cam belt it could be just a little tight and causes a whining noise that could be similar to what you have. Overtightened they can cause the idler pully bolt to snap causing piston and valvetrain damage.
Ok thanks guys, that info has helped heaps!
This is what I've figured out:
-the noise is coming from the front of the engine, was hard to figure out before.
-My a/c is not working so could be the a/c compressor.
-My cam belt was changed last year according to owner, it has marks on the cam angle sensor so I'm sure he was telling the truth.
Action:
-Gonna undo belts to a/c, power steering/alternator and start up and see if the noise was one of those.
-If not it must be the cam belt bearings.
Is changing the cam belt bearings very hard? Where do I get them from? Expensive?
I'm hoping it's the a/c compressor, cause will be easy to fix, there's a few for sale here in NZ.
Gonna check this weekend, do NOT want the engine breaking from the cam belt stuffing up.
Dave
    • Ok I get you. But isn’t the butterfly intake a headache with the +T?  see this is my plan so far but please advise me into the right direction.  Nistune Ecu, 1000cc Bosch injectors, TD05 or TD06 Kinugawa turbo using stock rb25det exhuast manifold, walbro fuel pump unsure of model I think it’s 450/460, spitfire coils and sparks to suit and a R35 MAF sensor and boost sensor.    I was thinking maybe do a cheap eBay plenum $400-500 or try find a stock det neo intake. I think I’d port match it so it’s getting the full capacity but open to advice please.  Thanks
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
