hey guys,
after I start my gts25t from cold it makes a kindof bearing noise whine, (I think) it's not too bad but noticeable. After 5 mins it goes away.
The noise changes with the revs.
I thought it was the gearbox, but it still does it when I push the clutch in.
Also thought it might be the water pump/alternator/a/c/power steering but don't think its that cause it sounds like its coming from the back of the engine.
Any ideas what it could be?
The engine has done 130,000kms, seems in good condition apart from that.
It's standard and was automatic until last year so don't think it has been thrashed.
The fuel pump, afm and water pump have been replaced. (previous owner said)
Can I put a metal rod onto the engine somewhere to "Listen" to the noise to figure out which bearings it could be? Whereabouts would i put it to listen to it?
Is it hard to replace bearings inside the engine? Do they cost a lot?
I'm mechanically minded, done gearbox changes etc but haven't opened up the engine before.
Also do 25t gearboxes cost much for bearings? Can you replace them yourself?
I'm worried if I leave it, it might stuff up the whole engine.
Dave
https://www.sau.com.au/forums/topic/54651-bearings-bearings-bearings/
hi, check the following.
press clutch pedal in about 10mm, if sound goes away it is the thrust bearing that presses against the clutch fingers.
press clutch all the way in, if noise goes away it is likely to be the layshaft bearing( at front of the gearbox)
other bearing noises are as you listed and also the cambelt tensioner bearings. can listen to cambelt cover with a screwdriver handle to your ear - assuming of course you dont have long hair etc that will get caught in fan...
I replaced mine about 140-150000kms on my RB20det, one was fine, the other sounded raspy and feels rough when you spin by hand - i replaced both. If you can do it yourself you should be able to get the bearings for under $200 pair.
Stephen
Also, if you used a new cam belt it could be just a little tight and causes a whining noise that could be similar to what you have. Overtightened they can cause the idler pully bolt to snap causing piston and valvetrain damage.
Ok thanks guys, that info has helped heaps!
This is what I've figured out:
-the noise is coming from the front of the engine, was hard to figure out before.
-My a/c is not working so could be the a/c compressor.
-My cam belt was changed last year according to owner, it has marks on the cam angle sensor so I'm sure he was telling the truth.
Action:
-Gonna undo belts to a/c, power steering/alternator and start up and see if the noise was one of those.
-If not it must be the cam belt bearings.
Is changing the cam belt bearings very hard? Where do I get them from? Expensive?
I'm hoping it's the a/c compressor, cause will be easy to fix, there's a few for sale here in NZ.
Gonna check this weekend, do NOT want the engine breaking from the cam belt stuffing up.
Dave
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
