Group Buy: Braided Brake & Clutch Lines
  • Replies 108
Righto, cables received... thanks Al.... although I can't help but feel that there's not enough hose... what about the hoses that run from the front of the car to the rear calipers? I'm assuming they're rubber as well? Or are they metal piping? I"ve never looked... time to read up on ripping my brakes apart.
OK. What is supplied in the kit is purfect, the only thing you need to reuse is the solid metal pipe that fits onto the Calipers on the front. Every bit supplied by Maltech is well labeled so is totally idiotproof.
The only thing i reccomend is that a GOOD quality 10mm Pipe Spanner is required because the fittings are extremely tight both undooing and dooing up and you dont want to round the fittings. I can't emphersise the GOOD QUALITY bit enough.
Fantatsic group buy Al
Ian
I got mine too. Went all the way down to drysdale (Geelong) to pick them up, but the Maltech boys were in Melb. that day. So I got them to ship em to me.
Rintaro, it is not too late, just post what you would like, i will update the first post (so Maltech can confirm the order) and follow the steps outlined in the second half of the first post (titled: What to do: ).
Allright, I'll see if I can do it Monday. I'm interested in braided brake lines for R33 GTS-t with red rubber end cap. So it's $356 delivered then.
Cheers,
Rianto
Mine are in along with my DBA 5000's.  Was pretty easy to do.  I recommend poeple buy a 10mm pipe spanner.  they are worth the money
Damn, that would be the next mod list :-P
Nothing is worse than a car that won't turn and stop well on the track :-)
Yeah I took my car for a test run and I'm happy to say that it's a completly different car. There is a huge difference between a stock GTR and one with a few dollars spent in the right place. Brakes and suspension first. More power later.
Guest
