Group Buy: Braided Brake & Clutch Lines
Scenario:
You have a 1300kg+ whale moving at 60+km/h, on 195 (wide) cheap hard compound tyres (that were only bought to barely pass the compliance), you flick the wheel and stomp on the go pedal, unfortunately the momentum of weight transfer is pushing the car in the same direction you started with, due to the lack of grip and width of the tyres.
My suspension is about as modified/improved as most road driven cars would go. With the 19's traction is NOT an issue and oversteer is "on-tap" when wanted. I need better rims that have a greater width (ie:8 inch all round), better softer tyres with a lower side wall profile, to minimis flex (i.e.: 17's) :thumbsup:.
But you are also correct...
At the moment the car is set for grip/track. Front adj. sway-bar is set to hardest and rear adj. sway-bar is set to soft.
For drift I will be getting under the car and setting the front a little softer (to absorb some of the weight transfer and unsettle the rear) and the rear sway-bar to the hardest setting (to flick out easily).
Unless you are competing don't worry about weight. Get out there and have some fun (as i have seen you do). Just try to bet your previous times at the same track.
It's only clean on my half ;).
Hi Al, rather than thinking it was the rim n tyres, could it be your suspension setup that's causing it to understeer too much?
U got a nice garage there, looks clean :-)
PS: ANZ wheel just got back to me, each 17" matrix wheel that I have weighs about 12.5kg :D that's quite a lot of unsprung weight there, not including the tyres.
  • Replies 108
it'll be interesting if the weekend at winton is pouring down. it'll be a chance to test my new SP3000 tyres. too bad i think i wont have time to get the braided lines installed before then, but that's not stopping me.
Unfortunately some people still have not completed the Buy. Maltech have been generous enough to give us the lowest price on faith that all people that showed interest will come through.
Please keep your word and purchase these great lines A.S.A.P. As you can see from numerous previous posts, that the quality and fitment are second to none.
Thanks
Alan
PS: Glad to hear ALL the good reports :cheers:
Well that's disappointing to hear. C'mon guys, time to honour the commitment. I have to mention that at the start of the year at the motorsport expo the price for these was about $600 so this price is extraordinary.
While I am yet to get these on the track, I can immediately feel the improvement over the stockers for firm, positive brake pedal and about 1cm less pedal travel. This is great for me as I have my pedal setup for heel and toe and last time out I was having trouble braking without contacting the accelerator on the big stops at Sandown. I won't have that problem now. Plus the issue of having a 10 year old import (94 model) means that many items are just past their use by date and brakelines especially so.
when is this group buy open till ? Might grab the clutch line in Jan..
wish I could grab the brake lines, not sure can stretch the budget that far though :(
The joining date for the group buy has passed, so unfortunately if your name is not on the first post you have missed out.
But Steve, at Maltech, has stated that he will give a good deal for any on off purchases through SAU. Just call/e-mail them directly and mention you are from SAU but unfortunately have missed the deadline for the group buy.
I will also add my 2c, that these were money well spent. I found that I had a much higher pedal and less travel to lock-up point. Plus consistency of braking throughout the whole Winton Fun Day.
:werd: Best bang for buck upgrade!
Guest
    • Don't "upload" the pictures. Just copy the picture direct from somewhere (I usually am pasting screenshots or something else that I have on the clipboard as an image, not as a file" and just paste it direct into the post editor. Just like you were pasting it into a Word doc or something. You can't damage something if you lift it where you are supposed to. If you look carefully at the correct jacking points, you will see that they are reinforced right there. And nowhere else. That is where the "foot" of the factory jack is supposed to sit. That's why you need rubber pads with slots. 10mm might not be deep enough. Note also that the slots are not required if the pinchweld has already been slammed flat. You could just lift it at the correct spot with a flat pad, because the damage is already done. No point in making worse though, if it is recoverable. IF. Yes, that's called a chassis rail. You can lift carefully on these, if you spread the load. A decent block of wood is good. But keep in mind what I said before. Any time you start doing this sort of thing, you are off the normal path and into "be bloody careful", because it is obviously not stable. Dumb. The refinforcement is already there. See above.
    • yeah looks like they've been lifted there previously but with solid not slitted rubber blocks. I'd just bend them back (combination of vice grips or hammer with some sort of drift, then hit the area with underbody protection paint. As for the siderails, I'd call those chassis rails and that is exactly what I meant about being careful with the balance point. You can probably lift off them at the point where the 2 pieces overlap, but you need to be careful with the forward balance of the car if you do when the engine is in....sills are a better choice. I guess you could weld some reinforcement in the sill area near the jacking points but it shouldn't be necessary if you use blocks with a slit. If you do want to reinforce it I'd use square section equal or taller than the seam and then just use flat rubber blocks for lifting
    • driver side sidemember and jacking point (looks the worst by far) driver side rear jack point passenger side sidemember and jack point passenger side rear jack point   Ignore my mug on the last photo. Turns out I was just too stupid to properly use the forum's attachment feature previously
    • Fk me, I guess next time I will try to use the onsite attachments feature. I find it hard to work with so far though because I can't move the images to where I want them to be. I will try to make a separate post with just images. As for lifting. The work I need to do for now involves the exhaust and engine mainly, so the arm covering the jacking points is not a problem. But I don't want to bend in the whole sill or underfloor by lifting the car at the original jack points. I found some rubber blocks, 125 by 125 with a 10mm wide and 10mm deep cutout, which I'm hoping will work for not hitting the jacking rail. The sidemember, as seen in the service manual, are the rectangular frame rails that come from the front of the car and go alongside the gearbox and downpipe. Those that get crushed inwards if you use them for a floorjack. They are already slightly bent in from being used to hoist by other people. I think cutting off the jacking points and welding or bolting on a reinforcement plate along the sill might not be a dumb idea. Or is it dumb?     A 2 post hoist is what I'm gonna work with, but not for any underbody work, just leaky engine and exhaust work so far. Depends on what else I find that might need immediate attention. For metalwork on the sills I think I'd just bring the car to a panel beater. What's your take on getting rid of the original jacking rails and putting reinforcement plates along the sills?
    • Yeah titanium always looks cool but I don't need that, just regular pipes would be fine. But I am really struggling to find any full hardpipe kit that is still for sale.
