Anyone welcome to a fun day test and tune at benaraby off gladstone on 23rd november.So far:
*My 4 door--hoping for a really low 13 or even a 12
*3040 turboed series 2 gtst --hoping 11's
*T51 180sx ---hoping 12's
*Previously n/a silvia and 32 gts
*32 gtr
*32 gts-squizz's old beast--now doing 14.1's with an open diff
*180sx drift weapon
*bluebird sr20--doing 13's
*black huge turboed 33gtst
*silver series 2 gtst 33--13.6
*black series 1 33 gtst
*hopefully Ben and maybe a few more from streetmachines with their 11 second GTR's
and probably more and thats just from Rockhampton/Yeppoon, the local Gladstone boys will come too.Whack your car on the list if your coming.
I think it costs about $40 and scrutineering happens til about 1 and drags til 5ish.
https://www.sau.com.au/forums/topic/5467-drags-at-benaraby/
  • Replies 53
RESULTS:
*My 4 door--13.39
*3040 turboed series 2 gtst--didnt come
*T518Z 180sx ---squizz 13.45
*Previously n/a silvia and 32 gts --not ready in time
*180sx drift weapon--13.7
*black huge turboed 33gtst--kabooom bye bye pistons
*maroon gtst with t3/t4 hybrid--13.36
https://www.sau.com.au/forums/topic/5467-drags-at-benaraby/#findComment-96711
SR20 with HKS T51 KAI will probably spool up at about 5000rpm, and should run 10s
CA18 with HKS T51 KAI will probably spool up at about 5500rpm, and should run 10s
Perhaps you mean TRUST T517z or TRUST T518z?
https://www.sau.com.au/forums/topic/5467-drags-at-benaraby/#findComment-97143
yay for the skylines.....except mine:(
once again keeping those ankle biting little 4's at bay.
The fact that the skylines cost twice as much and were faster by .1 of a second means nothing.....heh heh.
That mph is awesome squizz, can't wait for next time, maybe some decent rubber would go down well.
As for me 300hp at the wheels and a stock computer just didn't go together ....too lean. Time to fit the t78 but not before the microtech and maybe a 3L bottom end.
https://www.sau.com.au/forums/topic/5467-drags-at-benaraby/#findComment-97604
i think ill have to run hondy next time and show you all how to run 20's!!! go the N/A fwd dorift slug
Bad luck with the skyline garthos but i guess it was never gonna last like that.....:uh-huh:
And to Gti-r boy bagging squizz about 13.4's if ur car really has 164kws at all four why can't you crack a 12 when even a standard Gti-R can huh? You never had your Car and u never had Squizz. Rematch time this thursday..........:shake:
https://www.sau.com.au/forums/topic/5467-drags-at-benaraby/#findComment-97723
    • So the clockspring is responsible for the indicators cancelling on their own? I thought that was the function of that green thing in the center (any idea what it's called?)
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
    • So, the other thing I've sorted is a baseline dyno run up at Unigroup's new location. The auto trans was a little unco-operative by both shifting down when the throttle was floored on the dyno (so Mark had to ramp it up more slowly than in a manual) and also by shifting up at 6,000 even in sports mode instead of the indicated redline of 7,000 Still, on a hot day it made 240rwkw at 16psi which seems about right for 300kw (400hp) through an auto at the wheels.  The shape of the curve is not quite right because it was not full throttle to about 4,500 to stop it kicking down, but until I can get a tune on the auto trans control this was the best we could do.....full boost will be well below 5,000 once that is sorted, I'll get some data logs when I can to confirm For comparison, the R32 made 255 at 12psi (at 4,500) on the same dyno with tune, n1 turbos, cam gears, big exhaust but otherwise all standard so the v37 is likely a little better out of the box. One thing that is very clear is that the standard water to air intercoolers are not up to sustained use at full throttle in warm ambient temps. After about 5 runs (so only a few minutes full throttle), it was pulling boost and timing and dropping 10-15% power. Unfortunately I didn't get that printout and the Unigroup guys are away at the moment, will try and get hold of it on their return. So, looks like a healthy engine to start modifying and the only real area of concern is the w2a heat exchangers which the aftermarket has plenty of solutions for
    • I maintain it actually looked really nice in person. So much so that I thought "No, this is illegal" but there it was, clear as day. I think we can easily call the wing and wheels/height to be transformative. Not saying it's better than the GR Whatever, or the 86, or the WRX STI or anything of that sort (the internet says it all bolts up so you can buy best of all worlds?) but it's still at least a thing and not nearly AS bad as people say.
    • That's less offensive than the previous gen.....except for all that ugly black tupperware around the edges. Blerck!
