Hi,
You always hear about the hp of F1 engines and CART engines. I've heard anywhere between 800hp (approx 615kw) and 950hp (approx 730kw) for F1 engines and 750hp (approx 577kw) for CART engines. Any idea the level of torque these engines have. I think someone said a couple of years ago that F1 engines have around 700nm. I guess torque isn't as important due to the low overall weight. Has anyone have some info they can share.
Note: All hp/kw figures are at flywheel.
Cheers
https://www.sau.com.au/forums/topic/54694-torque-of-an-f1-engine/
im pretty sure its 19,000 RPM, not that it would make much of a difference
Different teams use different rev limits depending on track/engine longevity etc..
so there is no set limit, but most teams run betwen 17000 and 19000 depending on the track.
if u watch f1 lately you would have seen they show live telemetry on the screen that shows speed and revs... pretty good to watch the revs rarely drop below about 13500 in most races.
The revs you see on the TV aren't accurate. ITV use the accustics of the engine to determine the RPM. Teams wouldn't want to give away how many revs their engines are producing to the opposition.
Check out
http://www.f1technical.net/article13.html
Check out
i knew that all the teams are secretive about the specs of their cars, and was surprised when i saw the revs on the screen, you have just resolved that issue for me! i knew they would never reveal their revs :mad:
I once heard Martin Brudle say that the pistons in an F1 car about the size of a biscuit!
Hence how they get them to rev so hard.
Also the reason why they only last 200km ;) maybe 300km these days.
Actually, the piston size has has much to do with the displacement requirements too. The high revving has a lot to do with pnuematic lifters.
New regs say that engine has to be a 2.4L V8.
Simply, they are the old V10's with 2 pistons chopped off the end. This would save teams having to R&D engines from scratch, hence costing more money.
Yeah if it weren't for pnuematic valves they would have real issues reving high cause of valve bounce.
holy shit... 2.4L V8?? im interested in seeing what kind of power they'll end up putting out. But in the past, for example when the V10 3000cc rule was implemented the cars still pulled out record power and broke lap records, so the engines will still be poweful but ill miss that high pitched scream which they have down the straight... it wont be the same ;)
I heard these rules were put in for cost cutting and to attract more teams into the competition by making it cheaper to compete. Are there other reasons??
holy shit... 2.4L V8?? im interested in seeing what kind of power they'll end up putting out. But in the past, for example when the V10 3000cc rule was implemented the cars still pulled out record power and broke lap records, so the engines will still be poweful but ill miss that high pitched scream which they have down the straight... it wont be the same :D
Yes because ferrari can afford to spend billions on on part of their car when other teams have even less money for their whole car.
I don't think That figure of 400nm is right. The Honda VTR1000S SP2 is 99Kw/102NM, and that is a simple 1 liter production engine. There is no way a multi million dollar motor is only going to put out around 400NM. But in saying that I don't know what they put out.
I also heard on RPM that teams are going to run a breakaway series in 2006 (Date?).
The figures are pretty much on par. F1 engines really lack torque. Engine manufacturers chase after power, not torque.
The breakaway series is after the current Concord agreement which expires after 2008. It's all about Bernie Ecclestone's profit from the F1 series. The teams want a more bigger slice of the action.
I was watching the Indy cars for a little bit before work last Sunday, and they say they were running Turbo 2.4ltr V8's??? Weird combo, altho i understand that higher revving engines seem to have less displacement, but i thought it was interesting to see a small capacity V8 with a Turbo and they said around 700hp :D
I like it. Compact'ish V8 with a blower, think that would be cool to see in a production car. Altho it seems torque may be a problem
So is Indy the CART thing people are talking about?
Are the F1's going to go Turbo again? Oh yeah, the Indy engines were running STUPID boost, i must have heard the commentator wrong, 30-40 psi??? Must have heard wrong...
cheers.
im pretty sure that turbo's arnt going to ever be allowed in F1. They have rules against the forceful manipulation of air.
I remember reading about the F1 fan car, which basically used a gaint fan to suck up air from the ground (thus keeping it down), that model was scraped due to the rule that was put in.
    • It is possibly 55 degrees for the Nismo version. I had a look through the manual and the stocker has a breakaway torque of 2.5 to 3.5kgm. Supposedly the Nismo LSD goes down to 5kgm when worn in but it is pretty grabby even with very little throttle. Worse when cold. So I guess you have three things. 1. Shims. 2 Friction plates 3. Cams Would think shims would be the easiest but Ive no clue how many tenths of a mm shim thickness change equals how many kgm torque. Also not sure if the Nismo friction plates are similar/different to stock or if they are the most of the source of the diff being angry. Think I can write off the Nismo rebuild kit for the standard diff as not being what I want.
    • Yeah, it was a bit of confusion with me, I rang and asked if they had a boot for a soft top, and then the paint shop when they rang and were asked if it had a hard top on it, which it does, just not a PRHT....LOL Meh, whilst frustrating for all concerned it isn't a war stopper and should be a thing of the past in a week or two In other N/A related news, car is booked in at the end of the month for the cams, springs, retainers, harmonic balancer and retune  I might even pull the lazy arse card and get them to do a full service on it whilst it is there
    • Factory LSD is supposedly a 2 way with a very conservative cam. If you've already tried adding friction modifier to the diff oil and it still locks up too much for your liking you might want to adjust the ramp rate on the cam to be more like OEM instead of reducing initial torque even further. People claim the 8 kgf-m disc kit for the OEM LSD is still very streetable but I've never been able to compare everything side by side on my own.
    • Oh man, at least it sounds they've accepted they stuffed up and not put it back on you...could see some confusion if they asked if it had a hardtop or not, and you've answered truthfully but maybe not answering their real question which is what roof did it have from the factory! Glad your keeping it N/A 2.5
    • Nah, I much prefer colour matched Talking about colour matching stuff, the new/used boot lid turned up, all painted up perfectly......aaaannnndddd, it's for a power retractable hard top, not a soft top.....LOL They are now sending a boot to fit a soft top.....,  whilst frustrating, life is like that sometimes, sometimes you just need to dodge, duck, dip, dive and, ummm, dodge.
