Hey Guys,
I got a bit over a month until I turn 21, so I figure I better start organising. :alcoholic
At the moment i don't even have the slightest idea on what to do...?
Anyone who has turned 21 and had a great party let me know what you organised, or anyone with a good idea.....
So you know..
House party is out of the question as I live in the city in a tiny town house bearly big enough for 20 people.
:rave:
Let me know your Ideas...
https://www.sau.com.au/forums/topic/54703-ideas-for-my-21st/
yeah, had an 18th a couple of years back, but it was porn and pj party, but pretty much similar to pimp and pro.
I'm turning 21 November 28th, so we must have close b'days :) I have NO IDEA either what to do. I wanted something down at the beach, but you have to get a permit for drinking, and also there's the issue of weather :confused:
not sure what to do either.
just go clubbing man.
start off at the house drinking, go out for dinner (when half retarded), keep drinking... then finished dinner (3/4 retarded)
then go clubbing.
but make sure you get a guest list, that way your gauranteed to get in and not have to put-up with wanker bouncers
Not a bad Idea rigga, What did you end up doing?
I doubt I would be able to fill 'the eagle' though its a pretty big place....
Its not really all that big once they close off the pool table area and outside. I ended up having it in the Odean room behind the Eagle Bar. It was too cheep/easy to pass up and you can provide your own grog. Having it at a pub/function room usually means big $$$ for grog. I had about 120 people and the place looked pretty full.
You're born on the same day as my cuz ;)
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
