Mate what a storm!!!
About 1:30 - 1:50 am the wind is howling her tits off and hail and rain is pelting down. The carpark at work is 15cm deep in hail in some points and our store was leaking. Freaking mad, I was outside in the rain making hail balls as I've never seen snow and this was pretty damn close, it even made the crunch sound when you walked on it.:)
I am a simple, simple man:uh-huh:
https://www.sau.com.au/forums/topic/5477-whoa/
I got waken up by Window cracking sound this morning around 3:30 am... from under car park at my place.
so I thought farking thieves again so I took trusty Number 4 iron phone then went out side...
it was still dark and raining a bit also the wind was just too strong...
I go down there I saw my car was ok :) and other cars all ok exapt this one lancer parked quite far away from the enterance of building had cracked window on the passanger side. and that's it.
I did see anyone but I must been scare the theives away.
heheheh some asian dude, half naked and swinging number 4 golf clubs iron and shouting out, who wont be scared :eek1:
anyway I felt sorry for the owner of the car cuz he wake up this morning seeing the his car window is Broken... well I was not happy when my car got broken into...
fark I should tell people to upgrade te frekin car park!
anyway thanks for reading
cheers
Joe
https://www.sau.com.au/forums/topic/5477-whoa/#findComment-83644
    • My crystal ball says that when they replaced the pads, they didn't replace all of the brake hardware (could be a missing shim, pin, spring, etc).  Finding a low dust pad should be very easy. Have a google for things like, low dust / soft pad compound / easy on rotors. Your dust primarily comes from the rotors getting eaten up by the pads.
    • I think old mate is going to continue to hold out for awhile at that price
    • OBD1 is a catch-all term for pre-OBD2 which could have basically any connector design and protocol. I really don't understand this attitude against using data logging for issues that can be multi-causal and subtle. A no-start situation or something like that sure the scan tool does nothing but if it runs like shit it can often be a sensor issue. When a friend of mine reliably had issues with his N54 not able to stay running eventually I narrowed down the issue to a faulty fuel pressure sensor. Only way I could do that was a scan tool to look at the fuel rail pressure and see shadow codes for fuel pressure. Then check against a pressure gauge. Is reflexively firing up the data logger probably a bad habit? I guess, it can encourage people to not listen/observe but on these old OBD1 cars just taking a log really doesn't do anything by itself. You still have to synthesize everything you know and think about what it all means.
    • https://www.carsales.com.au/cars/details/1999-nissan-skyline-gt-r-v-spec-bnr34-manual-4wd/OAG-AD-24005316   i reckon some former Skyline owners are wishing they held out a little longer before selling up?
    • Yeah saw that video on YouTube. But he got a R grade (repaired) high mileage model and proudly advertised the fact it was super cheap and no doubt with issues. I wouldn't be going the cheap and nasty route.
