Popping from exhaust at WOT?
joh21m
 Share
I just had an fmic installed and when i give it full throttle it will start to pop after about 5000rpm. Wat could be causing it to do this? Is it a bad thing? My mods are as follows:
RB20DET
Turbo back 3" Exhaust
FMIC
POD
13psi (No boost controller...what the?)
Joh
Hey!
Is it backfire? You'll normally get alot of backfire when you have an after market exhaust. This is normal especially if you run boost. Happens after the fmic was installed as there is more pressure built up n released through the exhaust.
Hey!
nah its not backfiring its more like popping/stutter, i did a search and it seems its either the plugs or the coil packs, does anyone kno if the ngk plugs bcpr6es are already gapped to 0.8mm?
 Share
