Well, i have a problem with my car...
whenever i go over 100 my car starts to shake. when i reach 120 it really starts to shake. Does any body have any idea what might be wrong with my car. the shaking seems to be totally dependent on the speed as it doesn't matter how many revs the car is doing.
i suppose it's got something to do with the suspension? as a prblm with the motor would be more to do with revs than speed
Any ideas?
Kor
https://www.sau.com.au/forums/topic/54779-shaking-car/
cheers dude!
I had this problem but even a ballance did not fix it. I thought it may be a buckled wheel but I found out most mags are not made to be vehicle spacific and hub sizes will vary from car to car. You could try Hub locaters. These are small plastic rings that sit in your wheels and this leaves no gap between the wheel and hub. It worked for me but because I had driven with the shudder for a while the tyres needed changing because they were worn unevenly. With new tyres and the hub locaters I dont have the problem anymore.
Hope this helps.
https://www.sau.com.au/forums/topic/54779-shaking-car/#findComment-1071075
umm i had exactly the same problem..i got my car wheel balanced and also the hub locater thingy done and the problem was still there.
What i foudn was that my rear side mirror was the thing shaking. I always thought that my back window was shaking sso i was like wTF???...but den i figured my rear side mirror shakes whenever i go over 100. I have no idea why tho.......i still have figured out how to fix this...its quite weird actually
https://www.sau.com.au/forums/topic/54779-shaking-car/#findComment-1072082
no, i got my wheels balanced yesterday, all of them where slightly out, but they had all been balanced by the previous owner. now the car is not shaking anymore. But yeah my side mirrors, and rear view mirror have been shaking too. But at least the car isn't shaking?
https://www.sau.com.au/forums/topic/54779-shaking-car/#findComment-1072304
    • So either way it is gearbox out and look what is wrong?  I know about the input shaft bearing. Even before swap/new clutch the it sounded exactly like this: So is that inout shaft bearing or the other was installed backwards?  And can some please tell me the part number for that input shaft bearing? The gearbox is small box from R34 N/A and number is FS5W71C. Thank you
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
    • D2 and Ksport are essentially the same thing and basically just generic Taiwanese manufacture. Better than ChinaBay crap, but... not top shelf. Öhlins have got to be some of the best dampers around, so likely to be a good option. It's going to get to the point though where I suggest you buy from Oz. We have at least 2x excellent options here. If I were you though, I'd be talking to KW about doing something for the R33. There's bugger all difference between that and the 32. In GTR land, anyway.
    • KW only offers a set for the R32 GTR. Popular options are D2 racing, Ksport or Öhlins. I have a D2 Racing coilover set, though I don't know for sure which one.
    • Well, the good news is you have more than one very good option for new coilovers in and around your country. Worth the drive over to KW to talk about GTR stuff.
