i just read somewhere the neo6 uses variable valve tech
why doesnt the rb? wouldnt it help dramatically with low rpm/cruise fuel consumption and high end open throttle power?
does have 2 turbos make it obsolete? wuldnt u get even more power?
if so, is it possible to adapt the vvt from the neo to the rb engine?
https://www.sau.com.au/forums/topic/54818-rb26dett-vs-neo6/
The R34 GTR's RB26DETT has VVT from my understanding.
Don't forget, the older generation RB26's are designed way back in the 80's with the R33 GTR's engine being more a improved version only, not a complete overhaul.
You may be able to but that would mean use the neo's head and changing ecu's. Not sure though.
https://www.sau.com.au/forums/topic/54818-rb26dett-vs-neo6/#findComment-1071796
the power output of the RB25DET neo and the RB26DETT might be the same on the nissan brochure but in real life they are quite different.
The RB26DETT revs higher and puts out 50Nm more torque. The stock power figure is probably closer to 250kw. Fujitsubo claim about 247kw for a stock BNR34 on their exhaust website.
I offer to put mine on any 4 wheel dyno. I dont know where the nearest one is.
https://www.sau.com.au/forums/topic/54818-rb26dett-vs-neo6/#findComment-1072004
is that figure at the flywheel??
It would be expected that the NEO wouldnt match the RB26 but it seems that the factory figures (obviosly changed for the jap power laws) are extremely inaccurate. Also comparing RW figures on the NEO and RB26 would be difficult as the cars run with differnet drive setups.
Sewid, if your gonna put your car on the dyno, could you disconnect the front driveshaft :D
I want to know what the power difference 4WD and RWD is with the same engine
https://www.sau.com.au/forums/topic/54818-rb26dett-vs-neo6/#findComment-1072009
Yeah both power figures are innacurate - the NEO probably makes more than 206kw as well. There was a gentlemans agreement between manufacturers in the 90s that limited power output to 280ps (206kw). This is why cars kept coming out faster and faster and with more and more torque but still had 206kw.
Figures are at the flywheel.
If i could find a 4wd dyno I would not remove the drive shafts as I never really plan on leaving the car like that so am not personally interested in its RWKW figure. Bit of a hassle and im too lazy is the real reason though :D
https://www.sau.com.au/forums/topic/54818-rb26dett-vs-neo6/#findComment-1072013
Isn't 206kw the limit for the gentlemen's agreement?
I don't believe that the RB26DETT has 206kw stock at all like sewid says it has more in stock form and I don't think any RB26DETT has VVT (NVCS - Nissan Variable Valve
Timing Control System) at all.
http://www.tomei-p.co.jp/_2003web-catalogu...haft-specs.html
https://www.sau.com.au/forums/topic/54818-rb26dett-vs-neo6/#findComment-1072014
any of you guys read wheels about a year ago when they compared an N1 R34 GTR with a Monaro GTS?
They put the GTR on a 4WD dyno and came up with 215kw at all 4 wheels. this equates to 300+ kw at the flywheel. Tho this is the N1 with bigger turbos and more boost, im guessing the figure of 250 kw for the normal GTR R34 would be about right.
I read that the japanese 206kw agreement is off due to other manufacturers (international) making cars with much more than this and they want to be able to keep up.
https://www.sau.com.au/forums/topic/54818-rb26dett-vs-neo6/#findComment-1072126
    • Been over 2 months since I have done anything on the S15 and had a day off today so got stuck into mounting the radiator and intercooler. I ended up using factory bottom mounts as bolted in and I did order some gktech top brackets but didn't work with the PWR radiator so made up some with aluminium flat bar. Spent way to long on them but pretty happy how they are. Next job was the intercooler. Used some more aluminium flat bar and did the bottom mounts first. Top was easy as just one long piece and 2 90 degree coming off rad support and welded them on. The bumper support required some notching to let the outlets sit where I want so will add some reinforcement later to strengthen it. I have also bought ecu and waiting for it to arrive. Went with a Link g4x Xtreme but will be adding a ptmotorsport expander to add a few extra inputs over CAN. Went through a few different configurations on pclink to get what I want to allow future expansion for sensors and gearbox upgrades. Ordered gktech rear arms but looking at the hardrace lower control arms to have some extra adjustment too will see how the alignment looks after first setup. Got 2 more weeks of work before shut down and will have almost 4 weeks to work on this so planning on hopefully firing up mid January.   Also bought a 2015 brz with a heap of good gear, did noosa hill climb a month back. Owned it for 3 days changed alignment and sent it. Finished the weekend 2nd in class and only .3 off the 180sx best time last year. MCA Red coilovers, gktech rear lca, bolt on lock kit and tie rods, whiteline toe arms, cusco 1.5way diff and 4.5 ratio, endless brake pads, headers, exhaust, perrin intake and e85 tune. Electronic steering adjustment, nankang crs with koya wheels 17x9 +35. Have bought rear traction arm and relocation kit, extended studs and v3 tie rod kit. Planning on also getting flex tune as lucky to get 300km a tank with e85 and short ratio. Car is a heap of fun to drive and super easy to work on. AC in the line up at Noosa was mint in 35degree weather.
    • I'm 22 years younger than you mark, and I'm operating in the exact same way! Ha ha ha
    • All clamps are oem    one question is , what is the bit at the top on high pressure pipe where it connectes to intake manifold and other side goes toward the engine( see item in red circle in diabram attached)   ? Seen some people stating that should be removed on boosted application and skyline is boosted from manufacture so little puzzled. Mine is around 23pwi (700 hpish)   also some state it could be the bonjo bolt crash washer so bought two washers
    • what do you mean dead platform? People buy older, out dated and less power cars on "Dead platforms" for over $65k all the time.
    • That is really nice! Very nice finish when you have an oven to do the crinkling nice and evenly!
