hey guys ....
i had this problem for two days now ...
the boost is only 4 psi ... !! its some times reach 5 psi ..
it happend twice befor ... but it was for 5-10 minutes and then it gos ...without shuting down the car .. !!
now its there for two days ... i donno ... :hellpisd:
any help plzzz !!
i did ecu check ..(55) every thing is ok .. (just in case)
mods .. pod , exust and splitfire coil packs with iridium ix plugs ... only
car: 1998 R34 GTT
helpppppppppppppppppppppppppppppppppppp !!
https://www.sau.com.au/forums/topic/54851-4-psi-only/
yesterday i checked the solenoid ... its dead i think .. any way .. i'v changed it with small valve i made .. to give 7-8 psi and it works perfect .. (temprory) tell i find new solenoid valve ...
by the way .. the r34 actuator opens the weastgate at 4 psi .. the valve i made bleeds some air out ..and reduce the pressure on the actuator (if any body intrested .. i can post some pic )
fazt-r33 : ... as rhett said ... on the stock gauge its normal to show 3-4 ... any way check u'r solenoid valve
https://www.sau.com.au/forums/topic/54851-4-psi-only/#findComment-1073979
thax omran... but is i normal to show the same after 4500rpm... i thoug ist meant to hit 7 on the stock gauge.......
also i got a stage 3 hydrid boost controller... with solonoid and all the works.. jst can frekn figure it out.. the diagrams are to shtty and 2 general......
apexi bov for sale.... ne1 interested... 2nd hand with the gtst adaptor... fits 32,33 & 34... interested...?
https://www.sau.com.au/forums/topic/54851-4-psi-only/#findComment-1074121
QUOTE]
If it hits 7x100mmHg on the stock gauge that means you are running about 14-15psi i think, or close to double the stock boost. You know, there are different units for pressure around, psi is just a more common unit. bar is probably used second most.
https://www.sau.com.au/forums/topic/54851-4-psi-only/#findComment-1075800
  • 4 months later...
    • Uncle Duncan Yeap, FI Interchiller  Works well, normal IAT's cruising with the WTA only went from 50°c+ to 25-30°c with the interchiller  Before, when on it hard, the IAT would see 80-90°c, now, the highest has been was around 38°c IIRC IAT is measured under the blower hat I recommend it for the street or strip where your only on it hard for 10 or so seconds, but it wouldn't be efficient for sustained track use as it would heat soak from the AC turning off or whatever it does during WOT to protect the compressor It really needs the AC running for it to not heat soak and keep the WTA coolant chilled My WTA coolant temps when just cruising is around 2°c
    • Hey Mark...sorry to interrupt your career change to hair dressing... but...did you ever fit the interchiller to the commodore, and if so how was it? And, who made it?
    • I've been pondering this, I really enjoy the convertible thing, for me, it's like riding a motorbike, without all the issue of riding a motorbike, mainly, my old sore arthritic joints getting beaten up, and, being able to do it in shorts and a T-shirt and not needing a helmet and all the other gear required, especially like wearing jackets and pants in the summer, or needing 6 layers of cloths in the winter, or not having wet weather gear handy when your 100km away from home on the bike when it decides to start raining As for the hard top and its Coupe look, whilst I do lose all that open top feeling that I really enjoy, from my experience with the NB with a detachable hard top, the cabin is a much nicer place to be, the difference in noise for one, a hard top quietens down the interior, alot, with the soft top up or down it's pretty noisy, which, after 5 or so hours, can get tiring But, as you stated, the detachable hard top totally changes the look of the car, in a really good way, and for me, the look of a detachable hard top is so much better than the PRHT which looks more like a after thought with its weird bulbous rear roof line For me, the minimal effort of putting in on, or storing it after removing it, is well worth the time and effort for the look alone And yes, I'm sure the next owner will be grateful for it as well.......
    • I get into huffs with people when I suggest the MX5 looks so much better as a coupe than it does as convertible. Pretty sure I don't prefer the convertible version of anything. Good job on the hardtop! The next buyer will appreciate.
    • IMO wrap does have its uses, but like you said, quality wrap, and professional installation, would probably cost want a quality paint job does, but, the paint, if maintained, is basically for life, and much easier to touch up if required  In other news: it's pissing down here, with thunder, lightning and only some small hail "at this stage", luckily all "my" cars are undercover  I've also been contacted by a guy in Newcastle about the SS, he said he will come down next weekend for a look, we'll see how that transpires I guess 🫰
