hey guys, i was looking at getting a GT3071R with a 0.64 rear housing on a T25/T28 flange. was wondering if this would push to much boost for my stock internals. i currently only have 044 fuel pump , 3" turbo back exhaust, FMIC. i would obviously be getting a ECU remap straight after and have already got a boost controller. ANY HELP PLEASE ? my goal at the moment is 200rwkw+ but am looking to go further in the future!
  • Replies 70
As many others would say...Do a search!!
But i can tell you that a 3071 is overkill for 200rwkw...plus the flange is wrong...how much more than 200 do you want? 250? 300? 500? decide on what you want and then research from there...for lowish 200s you have several options...
  • 1 year later...
what sort of power should i get with the following mods,
i just copied and pasted im aware the a few things wont increase how many kw i have ;) lol
Nismo GT-R Bodykit
East-Bear Bonnet
Koyo Radiator
GReddy Spec LS Front Mount Intercooler
Trust Airinx Pod Filter
GReddy Oil Catch Can
Apexi "Pencil Type" Turbo Timer
Swoosh Boost & Oil Temp Gauges - Dual Gauge Holder
RS-R* Piping from Dump to Cat
Trust MX Exhaust Cat Back
KYB Short Stroke Struts - King Springs
Endless Carbon Brake Pads
what are the next few mods that should be on my list to boost a power but keep it fairly comfy as a daily driver
cheers
thanks mate,
any hot tips as to the next mods?
want to be hitting around 180 - 200kw at the treads
Read all the replies in this thread? If you want a budget 200rwkw get a r34 rb25 turbo, nistune, a r34 sidemount intercooler and full 3" exhaust. That will see you 180-200kw depending on the dyno and tune.
All the other stuff you listed is just ricey mods you don't need. Also if you are going to do the suspension do it properly and get some decent gear in there.
Edited by Rolls
sorry i was a bit lazy lol.
are the springs in it at the moment not that good?
i dont want to change the intercooler i have on it already
sounds like a new turbo and a tune is the way to go.
Oh if you already have the intercooler then def stick with it, king springs are pretty awful, if you are going to go to the effort of changing them put something decent in. I assume you will be paying someone to do it and labour will be the bulk of the cost. As for shocks KYB aren't bad but you could get something better like koni or one of sydney kids bilstein packages for not much more. The ride quality and handling will be so much better.
edit: Are those mods what you already have done? or you are looking at doing?
edit2: I assume they are ones you already have. In that case yeah just look at a retune and an r34 rb25 turbo. If you do every plan on upgrading the susp then I'd look into the bilstein kits but as you already have them no biggie.
Edited by Rolls
sorry i wasnt very specific, im buying the car on thursday if the mechanical says its all good.
these mods are already done.
the ones i want to do will be out of turbo, fuel pump, ecu and injectors.
depending on how much money i want to throw at the car
    • Thanks Pac!   I will reach out to them!
    • Yes, but 2 things of the top of my head, 1. Legalities of nitrous on a street car. 2. No chop chop. I fully understand that there's much cheaper ways to make power, and whilst a wet 50 shot is fairly cheap to install, bottle fills are expensive, and bottles always need to be refilled, and nitrous also has its own inherent issues with reliability, and tuning, from my experience of others using nitrous, it doesn't take alot to lunch a engine real quick if something goes slightly wrong when spraying, if I wanted a big chunk of additional powers, a spooly boy would make alot more sense, disregarding the additional engineering, supporting mods and other logistical issues of sticking a spooly boy on a car that came naturally aspirated from factory  In the end I'm not racing for sheep stations, and I don't really care if people make more power, or are faster than me, or spend less, or more than me, the only thing the car needs to do is drive around and make me smile, which it is doing now Really, I just want a shiny new intake to look at when I'm cleaning the engine bay, and of course, some more induction doorts, and maybe even that 5kw for that elusive 200hp cherry on top that I might get If the FAB9 intake plenum, TB and air filter box thing doesn't eventuate for whatever reason, Plasmaman do one, not as fancy looking, and a fair chunk of more cash is required when including the TB and other bits and pieces that are required to install it, but, it is another option that is available to me if FAB9 one does fall down (but I really, really.....really, want the FAB9 one though) TL;DR. You want what you want
    • Been so long since I have been here,seeing SDU is dead. I had that problem on my gtr in 2006 but luckily there was no engine damage,it was inspected by Hytech Engines,race bearings and extended crank collar put in and that was about it. Hopefully yours is sorted now.
    • Would it not be cheaper to just spray nitrous?
